Heil heat pump
I changed out the thermostat to a new Nest thermostat and the air kicked on for a few seconds and shut off. I switched back to old thermostat and still no power or air. Any ideas on what happened? It is a Heil heat pump.
  • Lisa parrish
    Lisa parrish May 10, 2014
    Hi Lisa parrish, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? It is a heil heat pump model YJ048gb1
  • Brian Mills Jul 11, 2014
    This needs more information, but I think you may have blown the 3 amp low voltage fuse located near the transformer in the air handler.
22yooper
  • 828 Answers
SOURCE: Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Posted on Jul 18, 2008
The HVAC Guy
  • 30 Answers
SOURCE: Goodman GSH130301AB heat pump with
the reversing valve wire needs to be on the o terminal.nothing will be on the b terminal on the thermostat
Posted on Oct 30, 2008
muttandjeff
  • 359 Answers
SOURCE: heil heater starts/stops before reaching temp
is installed in a vertical up flow or horizontal position , if in horz position you could have a bad or miss positioned roll out switch this is a thermal switch positioned toward the burner edge that if the flame rolls out of burner area trips and then resets as it cools allowing the furnace to re-start until it reaches temperature , something to check .
Posted on Dec 09, 2008
  • 16 Answers
SOURCE: central heat not blowing warm air
Do you know if your unit is a heat pump or not? Sounds like it may be an electrical problem and yes you would need to call a service tech.
Posted on Jan 17, 2009
louislevel_2
  • 374 Answers
SOURCE: Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Posted on Mar 13, 2009
Heil nulk075dg05
You have a dirty or bad heat sensor. When you remove the front panel on you furnace you will see a probe that is 2 or 3 inches long that is in the flame when the furnace fires up. If it doesn't detect a certain temperature within the first 30 or 40 seconds it shuts down the furnace. You can either clean the probe off with sandpaper, or purchase a new one. They aren't very expensive and are easy to replace. In my experience it is usually a build up of carbon on the sensor and a good cleaning with sandpaper and alcohol usually takes care of the problem.
Feb 04, 2014 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Heil heater keeps turning on and then shutting right off. Reset interior and exterior breakers to no avail. When the unit will kick on heat does come from vents
How long do burners stay on? If they go out within a few seconds, the flame sensor may need to be cleaned. The control board you have shown is probably doing it's job by shutting down and something else is causing this. Always check your air filter first. More info needed.
Jan 11, 2010 | Honeywell International Heil Quaker...
When to change from heat pump to alternate heat
We says the outside can pull heat out of 40* air, below this change to emergency heat or it should do this with the thermostat on its own.
Dec 12, 2009 | Amana PTH123B25AJ Heat Pump Air...
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
My Carrier 58WAV136 forced air heater's problem is as follows - Thermostat works fine, when desired temp is reached, the fan motor (blower) kicks on. Sometimes it stays blowing for a couple of seconds,...
There should be a code list inside the furnace panel access door. Find it and see what code 41 says, as I can't remember right off hand. Some of the possible causes could be air in gas line or low gas pressure. Could have blocked vent especialy if vented with plastic. Check for bird nest or dirt dobbers in vent. If vented with plastic could not have proper rise 1/4 per foot and have water trapped in pipe blocking vent. Is this a new problem or has this occured since installation?
Oct 07, 2009 | Carrier Heating & Cooling
Blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Dec 13, 2008 | Honeywell CT3200 5-2 Day Electronic...
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
