Question about Belkin (F5D7230-4) Router (587009)
Wireless set up laptop only has wireless slot for card no phone plug ins. no other computer. how do i set this so it will work?
  • 193 Answers
U can not connect any phone to the router first connect a pc through the router and login to teh router screen >and go to wire less settings and enable ssid broad cast>and change teh ssid name which u can easily remember one and save settings>and reboot all teh w/l laptops>and click on the right side w/l i-con>and search for teh ssid that u changed and click connect u can use ur w/l connection rate me solved if its helps thx
Posted on Nov 15, 2007
Motorola 1c743 wireless adapter reset
You modem needs to be powered on, linked to your cable or phone connection, and then linked to your router with an Ethernet cord. You also need a base computer (connected to the router with Ethernet as well) to adjust your router settings, like password and router name, and assure that you are communicating with the Internet.
Install your wireless adapter software to your laptop or computer that will be using the Internet wirelessly.You will be prompted at some point during the installation to plug in the adapter. (If prompted, restart your computer.)
Plug the adapter into your computer or laptop. Some adapters come as USB-compatible (Universal Serial Bus) plug-and-play devices, and others are PCMIA (Personal Computer Memory Card International Association) cards that go into a special wide slot in laptops.
Go to your computer control panel and click on Network Connections when the software download is complete (if the control panel does not load automatically). Your new adapter should be now be listed. Select the icon and look at the description to make sure that it is connected. If not, right-click the adapter icon and click Enable.
Double-click the adapter to search for a wireless connection. Refresh the list of connections available until you find the name of your router. Enter any passwords that you set up for your wireless router and then connect to the Internet.
Apr 07, 2013 | Motorola Computers & Internet
Suddenly network card stopped work. can't connect internet
Try This: Unplug the power to the DSL Router for 20 seconds then plug it back up. Remove the power cord and battery from the laptop, then press and hold the power button for 30 seconds. Turn the laptop over and look for the screw on the Wireless Card Cover. Remove the screw and the cover (it may be a number of screws depending you your system) then unplug the antenna cables to the wireless card (normally a black and white or black and gray cable). Remember which cable goes where before you remove them. Remove the screw that holds the wireless card in the slot, then remove it. Put the Wireless card back in the slot and secure it with a screw. Put the antennas back on the wireless card and then the cover. Put the battery back in, plug in the power cord and reboot.
If the system still does not find your wifi card, the card might be bad.
*** Sometimes the wireless card will be under the keyboard or palmrest instead of the bottom of the computer.
Apr 05, 2012 | Computers & Internet
Just a question, I have a slot inside my laptop next to my wireless network card. This slot has a similar connection and mount. Is this for an additional wireless card or can I add something else in there?...
Wont take another wireless card, some people actually will have the extra card slot for a specialized card that you can use a phone from your computer. Two wirelesscards on the same computer would cancel each other out. From my rememberance about the two slots, is that buisness needs requested two slots, one for the wireless card and the second for the specialized card so the computer can be used as a overly large cell phone, or used by techs in the field to hook up ghost programs and dianostic tools.
Mar 04, 2010 | Acer Aspire 5720 6497 Laptop
How do i start the d-link wireless to my laptop
Hi there. First you need to run the cd install disk BEFORE you plug in your card. Insert the CD or download the install from D-link online. Follow the instructions to set up the software. Turn off your computer and make sure the card is plugged into the PCMIA slot of your laptop. If you are using it at home and your router has a WEP security code, you must set up the card with the same code to get online. Good Luck...
Oct 29, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
Type II PC Card Slot does not work
Probably the drivers are missing. Go to Start, Control Panel,Syatem, Hardware, Device Manager. There should be a line that says PCMCIA adapters. If it has a red or yellow check mark then the drivers are faulty. If it's not there the drivers are missing. Download a new set of drivers from
Apr 02, 2009 | Dell Latitude D620 Notebook
Trying to set up wireless laptop. Instructions tell me to input
The wireless connection device on a computer is used to connect to a wireless router that is connected to the Internet via an Internet Service Provider (ISP) and or to your home or the network where you work. You can also use it connect to a wireless hot spot (like an Internet cafe) for Internet access.
Your computer will need a wireless device either a built-in wireless card, or a PCMCIA wireless card that plugs into your computer's PCMCIA slot or a USB wireless device.
If you want to connect into the Internet wirelessly in your home, you need a wireles router that is connected to a cable modem or a DSL modem and to a ISP.
The wireless router needs to be configured (change the default settings) the SSID and encryption (WEP or WAP, WAP is a stronger encryption method) etc.
The wireless card needs to be configured with the same settings as the wireless router so it can communicate with the wireless router.
For configuration information refer to the wireless router and wireless card/device manuals.
Whilst the settings of these devices are similar between the various manufacturers, the methods they use to configure varies and you need to be precise in giving make and model of the devices, your Windows system and computer to assist us to give you detailed advice.
Feb 01, 2009 | Dell Inspiron 1501 Notebook
IBM R40 2722 1802 Error Message
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
May 28, 2008 | IBM ThinkPad R40 2722 Notebook
How do i go wireless with my acer laptop? (my laptop has an ethernet port) how and what does the router connect to?
You will need to purchase a PCMIA Wireless card , it jsut slots into the expansion slots on the side of the laptop , they look like a flat card slot, also the you will need to purchase a Wireless Router / Access point (AP) then plug you router into this , this will send out a wireless signal which you can then configure to pick up on the laptop.
heres a link to a guide i wrote , it will help you in setting up a wireless connection and also a guide on what to purchase.
goodluck :)
Apr 29, 2008 | Computers & Internet
Pcmcia dont work
Unplug the card from the slot and reboot your laptop without it in there. After your computer boots back up, plug your card back in and it should recognize it again.
Jan 21, 2008 | Zyxel ZyAIR B-5000 802.11b (zyairb5000)...
Wireless adapter
you can either buy a pcmcia slot card that slots in the side slot or a usb wireless dongle for the usb port.
Nov 06, 2007 | IBM ThinkPad T30 2366 Notebook
Belkin (F5D7230-4) Router (587009) Logo
48 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
