Question about Dell Inspiron 2200 Notebook
Delll Inspiron 2200 Laptop does not power on
Power lights and harddrive lights come on for about 5 seconds, then goes out. Has new power adapter and battery charging light does light up when unit is plugged in and stays lit. I can press power button each time and the lights come on for about 5 seconds and goes out. Unit seems to be getting power, but does not stay on for longer than about 5 seconds. Display does not have the chance to come on before unit goes out.
  • 244 Answers
You have all the simpthoms of an overheating laptop.
For starters, get a vacuum and **** all the dirt from the fan or fans on the back/ bottom of your laptop.
Then turn on your laptop. It should stay longer than 5 seconds.
If this solves your problem, then you are lucky.
If not, you'll need to have your laptop serviced, and clean the heat sink, and have reapplied the heat transfer compund on the processor.
Not a big deal, and not that expensive either.
If this answer helps, please don't forget to rate.
Posted on Jun 22, 2009
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Apr 13, 2013 | Dell Inspiron 1525 Laptop
Hi, I have a Dell Inspiron 1505. Recently, it would not start at all. When I press the power button, the 3 light would light up for a few seconds then all shuts down. Is it that the motherboard is gone or...
Hello, Akash.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 13, 2011 | Dell Inspiron E1505 Notebook
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2011 | Dell Inspiron 2200 Notebook
Where is the reset button on a Dell Inspiron?.
There is generally no reset button on laptops, if your laptop gets stuck, hold down the power button until the machine turns off.
Another options would be to remove the battery and the power adapter. And reinsert them after few seconds.
Dec 15, 2009 | Dell Inspiron 2200 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 2200 has been working fine, But now won't turn on.
1. Try and check the voltage output of your adapter using any ordinary voltmeter. It should have a voltage reading close to the dc rating printed at the back of your laptop.
2. Even if you have problem with battery, the laptop should power on. Otherwise, if both battery and charger is working fine, then there is a problem with the charging circuit that is built-in on the laptop's mainboard.
If charger is defective, then its more practical to buy a new one instead of sending it or repair. Repaired chargers can cause more problem for you in the future.
Nov 15, 2008 | Dell Inspiron 2200 PC Notebook
Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Oct 29, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
AC adapter for dell laptop inspiron 2200
You can order the part from this link
Dell_PARTS_ADAPTER
Once you open the link scroll down and select the second adaper in the list
60 Watt 3 Prong AC Adapter with 3-ft Power Cord for Dell Inspiron 2200 / Latitude 110L Laptops
May 20, 2008 | Computers & Internet
Dell Inspiron 2200 Notebook Logo
327 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
