Question about Poulan Garden
How to bleed fuel line 1999 vw passat? - Poulan Garden
  • 906 Answers
Turn the ignition key on for 3 seconds then off for 5 seconds, then on for 3 again and off for 5 again. After about 10 cycles you should be purged.
Posted on Jan 25, 2015
1999 vw passat v6 where is the fuel pump relay
The fuel pump relay is #4, counting from the left on the top row of relays. (accessible from under the dash) It should have a control # XXXXX 208 printed on top.
Oct 18, 2014 | Cars & Trucks
Erratic fuel economy guage 2001 VW passat
Sounds like it was not flushed properly and bleed of air pockets. Many engines have bleed screws to bleed all the air out when refilling.
Dec 06, 2013 | 2001 Volkswagen Passat
My 1999 vw passat will only stay on if we idle it. need help and a solucion. thank you
sounds like you may have a fuel problem you need to find out your fuel pressure i believe it should be around 45 lbs with key on if it is not then you probably have a bad fuel pump
Aug 17, 2013 | 1999 Volkswagen Passat
When driving my 1999 vw passat its dies
Check for possible fuel pump failure.
Check fuel filter.
Check air filter for obstruction in housing.Check timing belt for wear or stetching.
Jan 21, 2013 | 1999 Volkswagen Passat
Need radio codes for VW PASSAT 1999 gamma
Sorry...this code is only available from a VW Dealer or a Radio Decoding Service
Will not be available for free from anywhere on the Internet
May 25, 2010 | 1999 Volkswagen Passat
1999 VW Passat V6 fuel pump needs replaced. Where is the fuel pump located?
FUEL PUMP IS UNDER THE VECHICLE IN FRONT OF THE REAR AXLE OR IN FRONT OF TANK ON THE RIGHT SIDE.
Apr 29, 2010 | 1999 Volkswagen Passat
A have a 1.8 1999 VW passat , there is no power in the fuel pump, I need to know to location of the fuel pump and the number
99 passat have no low beams only high beams and daytime running lights with switch on lose low beams any answers?
Jan 12, 2010 | 1999 Volkswagen Passat
Vw passat rear brake assembly leaking
It sounds like either You have a caliper that has malfuctioned or that you have a hole in your breakline skmewhere. Have you tried to bleed the brakes recently?
Nov 19, 2009 | 1999 Volkswagen Passat
I have a 1999 VW Passat 1.8l turbo. It has codes P0300 and others
They may not be firing. I would check spark from coils. You may have a bad coil pack. Do check for any vacuum lines. You can go to autzone.com and register for full free online repair manual
Sep 23, 2009 | 1999 Volkswagen Passat
1999 VW Passat low idle
replace your fuel filter first. If that does not do it, then try an air-flow meter. (if the check engine light is on it may be an airflow meter.
Jul 10, 2009 | 1999 Volkswagen Passat
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
