Question about Whirlpool Duet GHW9150P Front Load Washer
What does dl mean
The washer won't start and it say F dl
  • 641 Answers
Check this website Dawn for the solution on your issue.
How to Fix quot DL quot or quot quot Error on Whirlpool Duet Washer...
Posted on May 10, 2014
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Kenmore Elite HE4t Washer won't start
Hello Ameliafaith,
E-Z job...
If you take your model on line... to SEARS
(I don't ordinarily recommend)... BECAUSE THEY COULD ACTUALLY ... decode your ABREVIATED part number...
110. blah blah blah... (45986??)
The other sites actually have helpful VIDEOS...
But I already wasted enough time on this floundering with your
erroneous number (wrong no.)...
You will see these parts are reasonably priced and
very popular.. meaning they INDEED FAIL ... alot.
Go here:
Washer Door Lock Assembly Part Number 8181700 Sears PartsDirect
Carnac the Magnificent
Jun 07, 2017 | Kenmore Elite 45986 Front Load Washer
The DL error just came on. Is there something specific we need to do to fix this? It has been working fine, but then all the sudden the error started. Upon initial machine start, it works fine, but then if...
Presumably it is still under guarantee/warantee? You should contact the washer's service department before doing anything else as 'DL' does stand for Door Lock (error).
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor needing an engineer's attention ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 16, 2011 | LG WM2277H Front Load Washer
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
I trried to start washer and a code dl came up
dl means there is a problem with the automatic door locking mechanism that engages before the wash cycle is started
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f dl mean
Hello, F DL means
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Ohm out the door lock solenoid and the door lock switches. This is most conveniently done at the central control board--use the wiring diagram/tech sheet to locate the proper pins to test from. Unplug the washer before starting work.
Thanks
May 19, 2010 | Washing Machines
My front loading washer wont start it flash E and DL i dont no what it means can you pls help me?
DL means door lock error. This happens when the door trys to lock 6 times but cant lock.
There a 2 things that create this problem. the door lock mechanism or the CCU ( central control unit )
Replace the door lock mech. first. if this does not fix the problem replace the ccu.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
