Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Fridge PFSS6PKW makes ice, no water or ice is dispense
Same problem. It is certainly making ice as I emptied the icemaker last night and it's now full again. No ice, no crushed ice, no water comes out of the dispenser though. When pushed, the switch does not seem to make a "switch activating" sound; rather, it makes a sort of funny sound I can't describe.
Thanks,
Rick
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
SOURCE: Icemaker problem crushed only not cubes
I looked at the plastic piece the solenoid was moving (from Guest's comment 03/07/08). Pushed the plastic piece up (had to push pretty hard) and it reset the solenoid to its' start/beginning position(-?) Plastic piece came back to lower position - was free to move up and down. The solenoid is working now (hear the loud clicking and see it pulling the plastic piece up) to get cubed ice, instead of putting it thru the crusher.
Posted on Mar 15, 2008
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
Ge fridge is not making ice at all
Make sure the wire arm is in the down position. If it is in the up position this signals the icemaker that the bin is full and icemaker shutsn off. Hope this helps.
Dec 31, 2013 | GE Profile PSW26P Stainless Steel Side by...
GEProfile model #PFSS6PKW icemaker knocking
There are no serviceable parts on that ice maker and it will need to be replaced if you find it to irritating. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | GE Profile PSW26P Stainless Steel Side by...
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Will not dispense ice
i have changed filter and it still is not making or dispensing ice what could be the problem
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
476 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
