Question about Maytag Dryers
I replaced the heating element and now it putting out steam and not catching lint
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Contact dealer, manufacturer, possibly wrong heating element.
Posted on May 10, 2014
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: will not heat
Your timer has a red wire (marked RH on the timer) disconnect it with the power off of course, check for continuity between this point and all other points on that timer. If you cannot get continuity even while slowly moving the timer manually all around the dial then you have a bad timer. Sometimes you can clean the points on the timer but most of the time you must replace it.
Posted on Mar 02, 2009
  • 574 Answers
SOURCE: LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Posted on Aug 25, 2009
  • 429 Answers
SOURCE: where is the switch to turn on the heating element
You are looking for thermal fuses, Should be two
Goto sears.com /Parts
Call up the diagrans and it will show you where to look
One monitors the drum the other the exhuast.
If one is bad replace both.
Posted on Mar 06, 2010
Not drying clothes or catching lint
Hi Diane, You have 1 of 3 Problems. Either your 1. Heating element is bad 2. Thermal fuse is bad or 3 Your timer is out of wack.
Oct 12, 2013 | Dryers
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
Dryer won't heat
Odds are the Heating element is out. Only repair is to replace it.
Oct 29, 2012 | Maytag Dryers
GE dryer, no heat?
Your heating element is most likely burned out . Have you made certain all of your lint vents for the dryer are not clogged ? Also , be certain to clean the lint filter every time you use the dryer. A buildup of lint in the dryer , in the hoses & on the back of the dryer inside in between the drum & the outer covering can get so hot it will catch on fire when the heat is working , and also , without a fire will burn up your heating element.
May 18, 2012 | Dryers
Dryer works fine except it does not seem to heat properly. Wondering how the element is installed and where I could find replacement heating element.
I would need a model number to look up your heating element.
I can tell you that chances are if the dryer heats, but just takes to long to get things dry the heating element is probably ok.
Poor air flow is what causes dryer to take longer then normal to dry.
You will want to check your vent for restrictions such as kinks or lint build up. Don't forget to check the outside hood as it has a flapper or even a screen that can catch lint.
If your vent is ok then you need to take the dryer apart and check for lint build up around the blower housing and fan.
Aug 02, 2011 | Dryers
Fire in my dryer
I wouldn't use the dryer for now. It sounds to me like you have a lot of lint build up in your dryer back by the heating elements which is catching on fire. It is a very hazardous situation. You will need to disassemble your dryer and clean all the lint out from around the heating elements and your vent pipes as the fire can spread into your vent pipe.
May 04, 2010 | Whirlpool LER4634J Electric Dryer
Where is the switch to turn on the heating element i took off the piece of the drum behind the lint catch and pulled out lots of lint but the dryer is not heating up i think it tripped a switch
Mar 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Aug 25, 2009 | LG DLE2512W Electric Dryer
Replaced thermal fuse ,ran cycle all the way than died again.Have had to replace fuse in past would usually get 9 months out of it .Replaced it dryer ran fine but after cycle completed dryer was dead...
Have you cleaned the lint out of the airways and the heat exchanger area? The lint filter traps most of the lint but not all, the airways and especially the area where the heating element is still fills up with lint. To get it out, you'll have to take the back off the dryer and open up the enclosure for the heating element and vacuum it out. The lint clogs the airway, which restricts the airflow, which lets the heating element get too hot, which is why the thermal fuse shuts it off. Otherwise, it would catch fire (and in some cases, still does). It should be good for another few years when you get the lint out. Good luck.
Aug 16, 2009 | Kenmore Dryers
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
