Question about Bose SoundDock Digital Music System for Apple iPod - White
No sound comes out of my bose sounddock, but i know i have power, how can i fix it?
SOURCE: Bose Sounddock Volume Control Problems
Well, there really was nothing to it.
I let it dry out for the rest of the day and it went back to normal, thankfully.
:) Juliyana.
Posted on Jul 22, 2008
  • 20 Answers
SOURCE: BOSE SOUNDOCK CONNECTRO BROKE
You can't - the repair needs to be done centrally as the company would be at risk if it sold electrical parts to people who aren't qualified to repair such items. Therefore you need to call Bose and have this repaired, however it's quite a common fault so shouldn't cost too much.
Posted on Dec 31, 2008
SOURCE: missing power cable for Bose Sounddock
i did the same thing.... i worked for ccity and when we were closing they were about to throw away the display soooo it found its way 2 my car... there was no power port... call bose and go through the automated bs and tell the customer service rep ur power cable died and u tested "ur friends power cable" and it worked fine... tell them u need both parts and if its like my item it should still b under warrenty and they will ship it for free. if not u can just order the parts.
Posted on Mar 10, 2009
  • 19 Answers
SOURCE: missing power back bose series1 sounddock
If i'm not mistaken you can find those on Bizrate.com.
Posted on Sep 04, 2009
  • 51 Answers
SOURCE: how to replace a fuse on a bose sounddock
Assuming you have a Sounddock Series 1 the Low end Bump -Bump, nine times out of 10, the Bump is the power supply connector inserted in the wrong orientation. Check you have the plug correct. If it is correct then look on www.invebo.com for the diagnostics video.
Posted on Apr 12, 2012
My ipod wont play in the bose sounddock. tried shutting off the ipod. dont think my sounddock has an on/off switch. did unplug all pieces
We have an HCL desktop computer. Though we had loaded Ac97 Sound Driver still the sound is not coming (totally soundless) Can you suggest what to do?
Jan 16, 2011 | Bose SoundDock digital music system...
Bose Sounddock failure
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original. Try the PSUif you can. The click is the PSU shorted that can be caused by a fault n the sound processor. Invebo will repair it for you too.
Sep 22, 2009 | Bose SoundDock® (Black) Docking Station...
Bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Jun 19, 2009 | Bose SoundDock iPod Digital Music system...
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
Jun 13, 2009 | Bose SoundDock Digital Music System for...
Bose ipod speakers not working just no sound it is powering up
Try the fallowing
First things first, unplug the SoundDock. Plug it back in and try again. Then take the Dock insert out....and try it again. If that doesnt work check the power cable. A common problem is that people plug it in the wrong way into the Bose SoundDock. If that still doesnt fix your problem. Bring the product to your nearest bose store if its still in warranty. If not, call 1(800)644-2673.
Hope this helped please rate.
-Ryan
Feb 19, 2009 | Audio Players & Recorders
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
47 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
