Question about Garden
Need to find out price of magneto for koler engine k1606t model number. older tiller motor on top. thanks
  • 88 Answers
You may want to contact PartsTree.com in Austin, Tx. They seem to have parts for just about every engine.
Posted on Jun 01, 2014
5 Suggested Answers
  • 42 Answers
SOURCE: model #100200 Rev disc needs replaced looking for best price.
Below is a link to that exact part with the best price I could find for you.
http://search.cartserver.com/search/search.cgi?cartid=a-8671&category=MTD_Parts&maxhits=20&keywords=GW-1919
Posted on Mar 11, 2009
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
  • 4736 Answers
SOURCE: I have an older Front
I did a little research and found that Sears Parts Central has the parts to rebuild the carb. In addition, I also located the Owners and Parts Manual for your Model. I am providing a link to it, so that you can take a look at it and decide which parts you may need to rebuild. Also, they stock a rebuild kit, if that's more inline with what you can do on your own.
http://www.managemylife.com/mmh/owner_manuals/27529/CRAFTSMAN-Front-Tine-Gas-Tiller-L0311230?brand_name_search=917291481+CRAFTSMAN
Since you sound pretty handy, I don't think you'll have a problem rebuilding it.
Posted on Apr 06, 2011
Hi i would like to know why do i only have fire on one side of my 23 hp kawasaki motor?
Assuming that you have checked the spark plug and confirmed that it has not completely failed, the most common reason is the magneto on that side has failed. (There is a separate magneto for each cylinder).
To replace a magneto, you'll need to look up which part is used on your particular engine. (You will need the brand (Briggs, etc.) and the complete engine model and type numbers from the id tag on the engine).
Then go to an intrernet parts seller and look up your part number. One place you can start at is at PartsTree
http://www.partstree.com/parts/
Once there, click on the engine icon for your engine and drill down until you find the correct magneto part number.
Replacing the magneto is simple, removing the top engine sheet metal cover involves removing a few bolts, and both magnetos are then readily available.
When installing the new magneto, you first screw it down at the furthest point away from the flywheel. Then rotate the flywheel so that the magnet is aligned with the new magneto.
As part of the new magneto, you will get a thin sheet of cardboard that you hold against the flywheel magnet and loosen the new magneto, allowing it to be pulled again the magnet (with the special cardboard spacer in between).
Use care as the magnet is quite strong and the magneto will be pulled to it with a strong force.
Now firmly tighten the two screws that mount the new magneto and slowly rotate the flywheel to remove the cardboard. Replace the engine top cover and your done.
May 24, 2014 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Canadiana (older model). Who makes it and does it use mix gas?
Most of the old tillers were 4 cycle engines not requiring oil in fuel . check at canadian tire for a filter but take your old one along to compare them
Apr 11, 2013 | Garden
I am getting no spark at plug. Briggs model 31c707 motor. I have charged battery, adjusted valves, verified fuel line clear. Pull spark plug put into wire hold to motor and crank (no spark)
Hello, the next couple of things to check would be under the engine lid.
  1. Remove the screen over the air fan on the top of the fly wheel.
  2. Remove the 4 bolts securing the main lid and remove. Depending on the year of this engine it may have a secondary cover that Craftsman put on that will need to be removed first.
  3. When the lid is off you will see the magneto coil right above the spark plug; just follow the spark plug wire up to it.
  4. Use a wrench to see if the magnet on the fly wheel is strong. If the magnet is bad or really weak the flywheel will need to be replaced.
  5. Next check the magneto ground out wire. It will be a small black wire on the magneto. Unplug it then crank the engine. If the engine starts plug the wire back on the magneto and if it shuts down there is a short along the wire. It should only shut down or short out when the key is shut off. You will need to find the short if this is the problem.
  6. If the magnet is strong and the above test still fails to provide a spark then it is likely that the magneto is bad. You will need the rest of the model number; it will look something like: 31c707- # # # # - # # The part runs somewhere around $35.00 from Sears, but you might find it on-line cheaper.
  7. Replacing the magneto is pretty straight forward from there.
  8. Remove the old one and replace the old one adjusting it as far away from the flywheel as possible.
  9. Turn the flywheel until the magnet is directly across from the magneto.
  10. Put an ordinary business card between the magneto & the flywheel.
  11. Loosen the 2 screws that hold the magneto in place just enough for it to tighten up to hold the business card in place.
  12. Tighten the screws holding the magneto & rotate the flywheel to remove the business card.
  13. Test rotate the flywheel by hand a couple of full turns to ensure there is no contact with the magneto.
  14. Replace the small black wire, spark plug and spark plug wire, then test fire the engine.
  15. Shut the engine down and replace all the remaining parts in the reverse order as removed.
You should be good to go after this. If this was helpful please vote yes. Thank You!!
May 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I NEED A CARBURATOR FOR THE ENGINE OH195XA-7TPXS
must be tecumseh motor, can't find that exact number tho 7TPXS does not show up. but a carb for that model would be part number 640346 if its the motor with the cylinder on a angle not straight up and down prices vary 65.00 to 80.00 cheaper is at psep.biz. you could have put alittle more info like tiller, lawnmower, brand etc.
Apr 25, 2011 | Troy-Bilt Pony Garden Tiller
Engine only running on one side
You didn't indicate what type of motor or tractor. If you only have spark on one cylinder and if it's a newer engine with electronic ignition, I would suspect the magneto armature. If it's older with points, then it could be the points. Points are under the flywheel, the magneto is next to the flywheel, follow the sparkplug wire. Measure the gap between magneto and flywheel before removing. When buying the magento, be sure to get the model number and brand from the motor.
Jul 23, 2010 | Garden
I have a older troy don't know model number i need a carb kit
You probley have a briggs & stratton engine. If so, look for the engine model number which will be on the cover. You will need model number and type number. Your carberator will be part of the engine specs. Then you can go online to
mtd/parts
and find the kit you need or take model and type numbers to your local lawn mower dealer and they will either have it in stock or order it for you. Cost is around 15 bucks.
May 28, 2010 | Troy-Bilt Pony Garden Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
Parts list for Kohler K161T engine was mounted on a Troybilt Horse - older model. Need stator number - would like to see parts list or internet site to access it. Kohler has no spark
I have a troybilt tiller with a K161T Kohler 7 horsepowe engine. I have replaced all electrical components, spark plug, points, condenser, stater, all wiring, and cleaned magnets, but to no avail. I still have no spark. The points open and close properly, the plug is gapped correctly. Does anyone have an idea?
Apr 05, 2009 | Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
