Question about Graco Nautilus 3-in 1 Car Seat
Crouch strap does this crouch strap go over childs legs? I am attaching chest strap and then attaching the crouch strap; I am just going over child in both instances. My daughter puts toddler legs thru the straps. Please advise which is correct.
  • Graco Master
  • 1,629 Answers
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
Posted on May 12, 2014
Noggin
  • 944 Answers
SOURCE: harness is broken
Here is the link for the user instructions for your model; http://www.gracobaby.com/assets/pdfs/instructions/ISPC070BB_ISPC063BA.pdf Check page 19 (page 21 of the pdf file) and look at the locking clips in figure c - these may be missing or incorrect. You can buy replacements or any other parts on this link; http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11 Hope this helps - contact Graco or post here again if you have any more questions :)
Posted on Apr 05, 2007
my3angels
  • 125 Answers
SOURCE: shoulder straps
There should be metal hooks on the backside that hook onto the loops at the end of the shoulder straps. They will definately be metal so should be easy to spot against the plastic back of the car seat. They usually are sort of rectangular and have one side that has a 'lip' so the straps aren't supposed to just slip off. (Though I can imagine the possiblity of this when the belt is not stretched as it is during use) Refer to your manual if you cannot find them. If you no longer have the manual, you should be able to locate one for downloading or viewing PDF file at the manufacturers website. Hope this helps! :)
Posted on Aug 19, 2008
SOURCE: car seat straps
I have the same problem with mine. It's an easy fix. Unlock the straps (pull the little gray release tab) and then pull firmly upward on the lap belt opposite the loose strap. To reword: If your left shoulder strap is the loose one, go the right side of the seat, where the LAP belt comes out of the seat, and pull firmly upward on that part of the belt. It will pull the slack out from the other side. I hope that was helpful.
Posted on Apr 13, 2009
SOURCE: Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
Posted on Jun 25, 2009
SOURCE: I took the cover off of my daughters graco comfort
Look for a Certified Child Passenger Safety technician in your area, so he or she can help you to put it back together. Go to this link http://www.safekids.org/certification/os.html click on find a Technician.
G.A.
Posted on Jul 20, 2009
Cannot fold down my rear seat to access the child seat anchors. is there any way to release the rear seat from the boot?
Child Seat Restraints - FSB Forums - FullSizeBronco.com
www.fullsizebronco.com/forum/23.../182333-child-seat-restraints.html
Sep 22, 2010 - My rear seat hasnt been mounted in 6 years and my son Wyatt has ....Join Date: Oct 2006 .... Tether Strap Anchor Attachment for the Second Row Center Seating ... With the rear seat folded forward, remove the bolt retaining the rear ..... If you can't track down the part, send me a PM and I will get my Ford ...
Solution for car seat anchor tether - Tundra Solutions
www.tundrasolutions.com/.../119126-solution-for-car-seat-anchor-tether/
Dec 11, 2007 - I have a 2004 Tundra and I just installed a forward facing convertible carseat. It's almost impossible to get the tether strap attached to the ...
Child Car Seat Fitment in Trucks ' IH8MUD Forum
Dec 02, 2015 | 2006 Rover 75 Connoiseur
Tip
How to Install a Child Seat
FOR LARGER KIDS: If the child is over 35lbs, use the belt and shoulder harness as you would an adult and simply extend the belt over the seat. You do not need to install any of the built in straps.
SMALLER CHILDREN (UNDER 35 lbs):
1) If your child is under 35lbs get the locking clip that came with the seat if you have a seat with a shoulder harness attached. Otherwise, it isn't necessary. Pull the shoulder harness down to the base of the waste strap and then use the locking clip to bind it into place.
2) For a smaller child you will need to install the built in straps like so.
3. Set the seat in place running the waist strap through the back of the seat and clipping it on the other side.
on May 06, 2010 | Baby Gear
Should I put some air holes in my childs toy chest as I worry that he may climb into it?
If you are worried that you child may climbinto the toy chest and get trapped then it would be a good idea to take someprecautionary measures to ensure that your child would be able to breath or getout of the chest without any trouble.b>
May 29, 2012 | Furniture
How do you put the cover and straps back on the carseats
We need a model number and date of manufacture. Most Cosco
car seat belts are long and thread thru the bottom first. Then up thru where the childs legs are, into the latch mechanism, up thru the chest clasp and out thru the upper back area. A small anchor mechanism on the back of the seat secures the belt on each side. Some belts are 18" long and there are 2. Use the same procesdure just bring both up thru from the bottom.
If you can post the model # and date of manufacture I can be more specific.
Apr 28, 2012 | Cosco Baby Gear
I took the straps off and can not put them back, can you help?
The Long strap goes under the seat and comes up thru 2 holes (each end goes up thru each side). The holes are on each side of where the child sits. They come up and weave into the latches that snap into the **** clasp. Upward toward where the child's head would be they go thru the chest clasp. Look at the writing on the clasp to make sure it is on right (letters read the name Cosco and arent upside down) and the belts should be behing the clasp (in at the bottom of the clasp and out at the top). Up thru the holes on the back of the chair at the height appropriate for the childs body. Out the back and down to the claw that is on a strap under the front that you can pull to tighten or press to release slack as the child gets bigger. There should be 1 or 2 (usually 2) slots for the ends of the straps to be slid on to. Sit the child in the car seat and adjust the belt system so that a finger can be slid between the belts and the child's shoulders. This should do the trick. Good luck and be safe.
Mar 18, 2011 | Cosco High Back Booster 22-200 /22-207
I took off the cover to wash and now I'm trying to figure out how to get straps put back on
This will help if you lay out the chest pieces and all the pieces you removed on the table first. If it helps, snap them together. Then, lay out the pieces with metal prongs that lock into the buckle that goes between your child's legs.
1st pull through the belt adjusting piece through the bottom cover ****.
2nd pull the square release buckle through the second ****, on top of the piece that tightens and releases. This is the piece that you push with your thumb to release the seatbelt.
3rd pull both side seatbelts through the respective side right and left and make sure they are flat.
4th slide on the two pieces with metal prongs on one left and one right seatbelt. Before you do this, ensure that you have put the correct piece on the correct side and that they will latch properly into the buckle. Snap them into the buckle to ensure you have it right.
5th attach the two respective chest clips on one right and one left seatbelt. Snap them together to ensure you have it right.
6th pull the top shoulder seatbelt straps through one of the top cover slits. If you have a newborn, then it will be the bottom **** at the top. If your child has grown, then it will be the top two slits. Ensure both seatbelts are pulled either through the same **** on either side.
7th after you have pulled the shoulder straps through the top slits on the cover, pull them through the slits in the plastic carseat frame. Pull them through until you see them at the rear.
8th attach on their respective sides the shoulder strap at the back of the plastic carseat. There is a big brass metal piece with "hooks" at the top. The shoulder strap has a seatbelt "loop" on one end that can be hooked on. Do this on each respective side and make sure it is secure.
Oct 26, 2009 | Graco Snugride
When installing the forward facing booster seat do you not hook in any of latches to the seat? We have model #22-757-MRC. My children are over 40 inches so I am swithching them to the booster seat. My...
your child's weight and the lap & shoulder belt hold the seat in place.  Run the lap part across your child's lap and the shoulder part should cross your child's chest and not cross his/her neck.  There should be some slots on the side near the top to allow some adjustment of the shoulder strap.
Sep 06, 2009 | Baby Gear
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Graco Nautilus 3-in 1 Car Seat Logo
127 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
