Question about Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
Samsung RFG297 not dispensing ice/touch screen not responding
My refrigerator is still making ice, but it will not dispense it because I can not switch back and forth from water to ice. It will dispense water but when you select ice it doesn't switch over. The touch screen options have also stopped working (energy saver mode, lighting, child lock etc) so I am guessing it is all connected but I don't know how or what to replace. Thank you!
  • 5 Answers
I'm no expert but because of the problems I've had with this product, I'm getting better. It sounds like you need to replace the Dispenser circuit panel, part #DA97-07821N. It cost about $170.00. You need to remove the old panel. You do this by pulling forward (by hand only) on the display panel from its underside. You will notice a small rectangular hole on the right underside that is large enough for the tip of a wide flat blade screw driver. You can insert it here to assist in pulling the panel forward. Don't insert it too far, only enough to give you some purchase on the panel. Start pulling on this right side and work your way over to the left side being careful not to break the tabs that hold the panel in place. There are two tabs on the right and two tabs on the left and one at the middle top. Once you work out the two tabs on the right, the other tabs will release more easily. Once the panel is removed, it is just "plug & play." Just match up the wire connectors the same way they were on the old panel. When the new panel is connected, insert the panel on to the left tabs first making sure that the wires are tucked into place properly and not "pinched" then work your way over to the right side and pressing the panel on the edges (press around the edges only, don't press the LCD screen) to make sure the panel is seated securely on to the tabs on both sides and the top. turn on the water and plug it it and you should be good.
Posted on May 10, 2014
Testimonial: "Thanks! I'm gonna try this ASAP!"
  • Brooke L
    Brooke L Jun 01, 2014
    Thank you SO MUCH this worked! The part was on backorder but I finally got it, $150 and about 5 minutes and it was fixed.. way better then the $450 Samsung wanted! Thanks again!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 51 Answers
The only thing I can think of is .. make sure it's not locked if not umplug it for about 5 min it should reset itself unless it have a resetting button somewhere ,sometimes resetting spot is a litlle hole that you can reset it with a pin check for it around the screen I know the ice machine has its own resetting this way also .good luck.
beamerguy740
  • 65 Answers
SOURCE: My new (2 months) Samsung refrigerator barely
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Posted on Mar 29, 2010
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
  • 122 Answers
SOURCE: I have a Samsung RF267ABRS
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Posted on Sep 03, 2010
  • 441 Answers
SOURCE: Samsung RS267TDRS Refrigerator -- no water coming
The most common reason water stops are 1. The water line has frozen, but its not the part in the freezer door. Behind the crisper bins in the fresh food section, you might not see it but it behind the back wall. Heat up that area with a hair dryer, or if its not full shut it off for 24 hours and it will do the trick. 2. The pump that sends the water to the dispencer is dead, it will be located behind the ref lower left hand side behind panel (follow the water line) part # DA74-40149D, you can order it at marcone.com for about 27.00
Good luck, if those dont work let me know
Posted on Nov 11, 2010
  • 2069 Answers
SOURCE: Samsung RFG295AA Ice maker
You could try to Reset the ice maker. there should be a red button by the side of the icemaker. After resetting, wait 24 hours and check if ice production has begun. please also check this very useful guide on how to get on otherwise.
If your ice maker still doesn't produce ice after following all of these suggestions, schedule your unit for service
Posted on Jan 06, 2011
I have Samsung rfridgewith freezer on bottom. We replaced the the ice maker but but now it makes ice just won't dispense
try defrosting the ice dispenser portion of the unit, it might have ice buildup stopping the auger from functioning
Jul 13, 2017 | Samsung Refrigerators
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Mold on Ice dispenser
If there is mold on the outside of the ice dispenser you should wipe it down periodically/ weekly or more often with a mild mixture of soapy water with a touch of bleach in it. Make sure that nothing in the refrigerator is blocking the port that ice is deliver through or that ice is not building up around the inside of it. And do not let water or ice lay stagnant in the door tray at the bottom of the dispenser.
Good Luck and God Bless
GodsAuthor
Aug 21, 2010 | Kenmore 53642 / 53644 Side by Side...
Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Oct 04, 2008 | Refrigerators
Dispenser does not dispense
SOUNDS LIKE THE MICRO SWITCH OR PC BOARD BEHIND THE LEVER IS BAD,REMOVE CHECK CHECK AND REPLACE IF NEEDED,MIKE
Sep 03, 2008 | GE Profile Arctica Stainless Steel Top...
Ice/water dispenser control panel
could be the dispenser board or the main board. hard to sort out without a meter. most likely the dispenser board but i have seen a dispenser board go bad and smoke the main board if that is the case you can damage the new component so check out the cost on the parts
May 07, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Dispenser not responding
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Aug 16, 2007 | Maytag MSD2754G Side by Side Refrigerator
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
270 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
