Question about Refrigerators
GE profile Fridge, Have to slap the back of fridge to get the compressor to work
The compressor has been failing at increasingly more frequent intervals. The remedy so far has been to splap the unit firmly 3/4 of the way up on the right hand side of the back of the unit.
    Habit-Forming:
  • 144 Answers
The contactor need cleaning or replace, look on the back of unit for the service port ( screws in sheet metal cover) and inspect the contactor and check the starter on the compressor.
Posted on May 10, 2014
  • Michael Myer
    Michael Myer May 10, 2014
    I havent been able to locate a contacter, from the diagrams i pulled it looks to be it is fired off a relay witch is powered by a capacitor. And the board just sends the signal on down to fire. The oddest thing is the place I have to hit it. I can tap on every part of the compressor system and nothing will happen but if I slap the back of the unit away from all the wiring and components, bamn comes right on.
  • Michael Myer
    ok, I checked the thermistors and the ohms are high and staying there, which would explain the defrost coming on. Going to replace the evap and the freezer and see what happens
GE Profile Arctica PSS26MG freezer thawed fridge not cold sounds like running rubber on fridge door hot as where it closes between freezer & fridge
The door frame has a heater in it to stop condensation and the freezer door sticking shut with ice.
As both freezer and fridge have failed, you need to call a refrigeration engineer, as it either needs more refrigerant gas or a new thermostat, or (hopefully not), a new compressor.
Oct 23, 2015 | GE Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Dec 29, 2009 | GE Profile Stainless Bottom-Freezer...
After plugging in the fridge the compresser does not come on. I looked at the electric panal and the fuse is still good. could it be my compresser? Ge profile. t
The compressor is controlled by the cold control. This is probably where your problem is. on a GE Profile, this is usually located on the back wall where you change the temperatures for the fridge or freezer. With the refrigerator unplugged, this control can be easily replaced, and you compressor should come back on! Hope this helps!
Dec 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer and fridge tempeture increasing.
The black " tank " is the compressor . Will the fan by the compressor run ? If not , that is the problem ( fan motor ) . Are the coils clean of dust , lint , pet hair , etc ? The brand and model number would have helped . Since the compressor is hot , means it should be good . The fan motor must be working , to help keep the compressor cool . Also , the back cardboard or metal panel must be in place when finished , or the fan will draw outside air instead of front air over the coils and compressor .
Aug 30, 2009 | GE Profile Arctica 25.4 Cubic Feet...
FRIG DOEN'T GET COLDER THAN 49, WHAT COULD BE THE PROBLEM,FREEZER WORKS GREAT (GE PROFILE) ABOUT 2 YEARS OLD-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Profile Fridge doesn't get cold. The top Freezer is working and seems to be always Running. Any Idea's?
Check at the back under fridge If 2 compressors then possible gas recharge to the fridge one
If 1 compressor check thermostat in fridge and/or that the temp control is not set at defrost [some do this by being pushed in like a push button on/off]
Jun 17, 2009 | GE PTC22MB Top Freezer Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
