Question about Admiral ATW4475XQ
Manual Admiral ATW4475XQ - Admiral ATW4475XQ
3 Suggested Answers
SOURCE: water level on rinse is
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Posted on Nov 19, 2011
  • 3 Answers
SOURCE: i have an admiral washer atw4475xq can you adjust the water level on the rinse cycle
Pulled this together from a couple of Solutions & added some helpful tips I found as I successfully changed the rinse cycle water level!
ATW4475XQ - Admirial Water Saver washer - Adjust Rinse cycle water level
The rinse cycle water level can be adjusted. Unplug the machines power.
You can youtube a video on how to remove the top control panel, its just 2 screws on the back of it,
phillips head. Swing the control panel up, and find something to support it so you have both hands free.
(http://www.youtube.com/watch?v=MYn0_qCFdec)
You'll see a clear plastic tube coming up from the back rear like 3/8 in diameter, to a "T"
connection. The one that goes to the left, thats the wash water level switch it connects to. The one you
can adjust, large, medium, small, from the front of the panel . The other off the T goes to the rinse
water level switch. There is not a knob to adjust it. But if you look at the bottom of the lever
mechanism/cam pickups of both switchs, you will see that they are the same. Rotate the wash load size
(knob on outside of control panel) from small to large, back to small, notice how the mechanism changes?
The rinse water level swtich acts the same way, although it is only a 2 position switch, small and
large. Once you watch the wash level mechanism move from rotating it back and forth a few times, you
should be able to see how to rotate that same mechanism on the rinse switch 1 click. It will click into
place, there are only 2 positions as I said and from the factory its in small, so once it "clicks in"
dont go any further. I did mine with a very small screw driver without removing the rinse switch.
Once you get that hidden switch turned to the other position, put it back together, fire it up and now
your rinse is the large level, all the time.
NOTE: There is a white plunger out of the end of each switch with a screw located in place. Dont mess
with the screw or that plunger. As you adjust the lever mechanism/cam this adjusts the amount of that
plunger sticking out, which changes the pressure pickup for water level.
Posted on Nov 11, 2013
Lid light is flashing, machine will fill with water but does not wash
lid light flashing would give me the idea that something is wrong with the lid switch .and If I can not find and fix that then I call a repairman
Oct 14, 2015 | Admiral ATW4475XQ
During wash and rinse cycles, washer stops loud buzzing noise, turn it off , wait a few minutes and will restart after a few more minutes will do the same thing again ??????
does it allow much water into the tub? u may beed to check ur water inlet valve for OHMS and for proper voltage at the coils, they may have went bad
Jun 02, 2015 | Admiral ATW4475XQ
My washer is not ringing my clothes out properly
check ur clutch, belt, motor coupler, or a plugged water pump or drain hoses
Feb 23, 2015 | Admiral ATW4475XQ
Admiral ATW4475XQ leaking from bottom but still washing fine
This could be a small hole in the drum or drain hose or valve for the water controls.
May 20, 2014 | Admiral ATW4475XQ
Circuit trips on the beginning og the was cycle.
If you experience the power circuit to trip every time the machine is put to start and when the water flows to load, it is possible that there is a higher current drain on the INLET Valve. You can disconnect and touch the valve to confirm if this is warm. If so there is a short within., Also it can be related to fault within the main board, the motor drive, motor and capacitor.
Feb 11, 2013 | Admiral ATW4475XQ
Admiral ATW4475VQD water won't fill
Does the lid switch work? With the lid closed, put the unit to spin cycle. If it spins, the switch is good and you will need to replace the water inlet valve.
Here is the switch if you need it.
Here is the water valve if you should need it.
Dec 04, 2012 | Admiral ATW4475XQ
Users manual for admiral atw4475xq
May 17, 2012 | Admiral Washing Machines
How do you take the control panel off of a ATW4475XQ admiral washer
Pulled this together from two other posts & added some details that I found as I performed the fix successfully!
Mar 17, 2012 | Washing Machines
I have an admiral washer atw4475xq can you adjust the water level on the rinse cycle
Nov 14, 2011 | Admiral AW22 Top Load Washer
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
Jul 24, 2011 | Admiral Washing Machines
Admiral ATW4475XQ Logo
46 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
