Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
How to reset LG TV 62DC1d-ab? - RCA D52W20 52" Rear Projection HDTV-Ready Television
I have an lg tv model 37LC2DB - EC I lost all my channels and can not auto programme so I did a factory reset now it says not programmed how do I get my digital TVs channels back
Re-program.
lg tv factory reset, not programmed? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Sep 21, 2011 - I performed a factory reset for my lg tv like I was told to do by the ... to get set for digital and now it keeps flashing not programmed anyone know ...
In my lg smart tv showing not programmed how to program ...
nordstromchicago.com/In_my_lg_smart_tv_showing_not_programmed...
My lg smart tv keeps saying its not programed it wont switch on .... And after all is done, then run Error Checking/Chkdsk using the instructions in the link below. How To Run ..... We got a new lg smart tv was up and running now says not programmedwhat to do .... I have tired Auto tuning and Factory resetting. but no luck.
LG TV Signal Diagnostics, factory reset and manual tune ...
? 25:30
https://www.youtube.com/watch?v=IxKcCbjLD4I
Sep 29, 2011 - Uploaded by 1976stuart1976
LG TV Signal Diagnostics, factory reset and manual tune - Post Digital .... one the net ran for a bit and now its telling me im notconnected and I ...
Jan 20, 2016 | LG Televison & Video
Oh I just put a new globe in my LG rear projection tv model 62DC1DA-AB and its flashing a orange light is that because I have to reset the glob and could you please tell me how to reset the globe
Yes reset,you should see a reset hole in the main body where the globs are fitted if it is user resetable if not you're stockist should be able to tell you where to take it please let me know how you get on.
Mar 03, 2015 | LG Televison & Video
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Jan 04, 2015 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
Our 50" LG Plasma TV has become stuck on one
Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so, and allow it to make a hard reset, and check. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | Televison & Video
LG projection screen television model 62DC1D-AB switches on then keep switching off and the symbol looks like a flashing light globe what does this mean
Your LG HDTV is in protect mode that why you can see light .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted or leak capacitor in power supply section.
Regards:
votit
Feb 03, 2011 | LG DU-62SY20D 62" Rear Projection HDTV
Hi, i have a lg rear projection tv model no. 62dc1d-ab and i was wondering where i can buy a new lamp bulb for it, lamp number p22-hd5, lamp model as-lx60, 31419sn984a. And i also need directions in...
Make sure your TV is turned off at the power switch for at least half an hour. Undo the two screws on the lamp cover which is on the right hand side of the TV as you look at the screen.
Remove retaining screws on lamp case.Lift up fixed wire handle on lamp. Pull out knob slowly and remove lamp case. Insert new lamp gently. Tighten screws. Replace cover.Reset lamp time on menue.
Sep 10, 2010 | Televison & Video
WELL MY 32 INCH LG THE REMOTE LIGHT ON THE VT IS OUT CANT TURN CHANNELS OR ANYTHING FROM THE SIDE BUTTONS OR REMOTE PLEASE HELP
Have you unplugged the LG TV, waited about 2 minutes, and plugged back in to try and reset the TV?
After you reset the TV, try using the key pad on the TV first before you use the LG remote.
May 18, 2010 | LG 32LC7D Television
Lg 62dc1d-ab rear projection tv. the picture has gone very darl even at full brightness
ure bulb will be on the way out go into the menu and there should be a lamp counter if its close to 8000 hours then its due for one, check ebay for cheapest price as they arnt under warranty
Sep 23, 2009 | LG Televison & Video
Tv turns off
My LG lcd tv did something similar, kept making a clicking noise every minute or so. In the end i took the back off and checked could see there was one popped capacitor on the power board. Replaced for £3 and has worked fine ever since. Hope this helps
Aug 30, 2009 | LG 37LC2D Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
