Question about Panasonic FV-08VKM1 WhisperGreen 80 CFM Ventilation Fan
Why does the Panasonic vent fan model number FV-08VKM run constant? What are the proper adjustments? why does the Switch has no effect on the unit on or off?
  • 34 Answers
Very simple you bypass the switch ,it is connected direct thats why you do not have the control.
Posted on May 10, 2014
What could be the cause of the fan not ventilating the room?
Is there a switch to recirculate,or fresh air ??
May 09, 2017 | Panasonic Dryers
Trying to wire a honeywell bath fan control to a panasonic FV-04VE1 ventilator fan cant figure it out. Fan control has two black wires and a ground and the fan has blue-yellow-and orange wires, what do i...
well, this is an interesting monster. It appears that the unit needs to have constant power and a control circuit. Here is the manual, wiring diagram is on page 8. So, you will need to feed power directly to the fixture, after this, you will need a minimum of 3 wires and a ground between the fan and switch location. Power goes down to the switch on the orange wire, When power is sent from the switch back up on the yellow wire, the unit is on, when this connection is open, the unit is in standby. When power is sent from the switch up the blue wire, the unit is in hi, when this connection is open, the unit is in low. I do not know about the switch you are trying to use, because you did not provide a model number. If I were wiring this unit, I'd use either two switches or a stacked switch.
Sep 17, 2011 | Broan-NuTone FAN CONTROL SWITCH
Can a normal two part wall switch run all three parts of a panasonic whisperlite fan/light/night light combo
Was it wired up there before with the 2 switches? One for the fan and the other for the light? You will have to take the plug out of the fan and cut the ends and wire nut them to their wire on the switch. Otherwise it be on when the switch is on. Or,,,, Find the right wire inside there and make sure it is separated from the light and hook it up that way, then it can stay plugged into the fan unit. Check it out, hope this helps.
Oct 16, 2010 | Panasonic WhisperLite Bathroom Fan with...
Panasonic fv-11vhl1 fan frequently makes noises while running; unit is 5 yrs old; all user maintenance has been performed. Is fan cage repairable/replaceable?
MOTOR SOUNDS LIKE IT IS GOING BAD, YES THEY ARE REPLACE ABLE, FIND THEM AT ONE OF THE ONLINE SUPPLY HOUSES, NO NAMES BUT IT RHIMES WITH DANGER
Jan 17, 2010 | Panasonic WhisperWarm FV-11VHL1 Compact...
Replacement bulb for Panasonic FV-11VQL4 fan doesn't fit
It' a unique bulb that is available online. The big box stores don't carry it.
Oct 23, 2009 | Panasonic FV-11VQ2 Fan
Replacement bulb for Panasonic FV-11VQL4 does not fit
YOu can try Panasonic for your light bulb. https://www.amazon.com/Panasonic-FDS18E35-18-Watt-Compact-Fluorescent/dp/B0039PMG2I
Mar 12, 2017 | Panasonic Kitchen Appliances - Others
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Feb 25, 2008 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
Panasonic FV-08VKM1 WhisperGreen 80 CFM Ventilation Fan Logo
127 people viewed this question
Top Panasonic Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
