Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Lg tv 62dc1d-ab red light stays on? - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • Graham Peters
    Graham Peters May 11, 2014
    I got into the lamp menu and I was stupid enough to adjust the temperature range, when I did it permanently placed a red lit light next to the temp symbol and the TV switched off. Now the TV will not switch back on, how do I reset the temp settings, can I factory reset the TV?
Light on bottom just stay red
I have a new power supply and my light stay solid red on my LG tv. Has anyone experienced this. I ordered the power supply from Sears. Someone please help a brother.
Nov 20, 2014 | LG 32LD550 32 in. LCD HDTV
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
LG projection screen television model 62DC1D-AB switches on then keep switching off and the symbol looks like a flashing light globe what does this mean
Your LG HDTV is in protect mode that why you can see light .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted or leak capacitor in power supply section.
Regards:
votit
Feb 03, 2011 | LG DU-62SY20D 62" Rear Projection HDTV
Hi, i have a lg rear projection tv model no. 62dc1d-ab and i was wondering where i can buy a new lamp bulb for it, lamp number p22-hd5, lamp model as-lx60, 31419sn984a. And i also need directions in...
Make sure your TV is turned off at the power switch for at least half an hour. Undo the two screws on the lamp cover which is on the right hand side of the TV as you look at the screen.
Remove retaining screws on lamp case.Lift up fixed wire handle on lamp. Pull out knob slowly and remove lamp case. Insert new lamp gently. Tighten screws. Replace cover.Reset lamp time on menue.
Sep 10, 2010 | Televison & Video
Lg 62dc1d-ab rear projection tv. the picture has gone very darl even at full brightness
ure bulb will be on the way out go into the menu and there should be a lamp counter if its close to 8000 hours then its due for one, check ebay for cheapest price as they arnt under warranty
Sep 23, 2009 | LG Televison & Video
Tv turns off
My LG lcd tv did something similar, kept making a clicking noise every minute or so. In the end i took the back off and checked could see there was one popped capacitor on the power board. Replaced for £3 and has worked fine ever since. Hope this helps
Aug 30, 2009 | LG 37LC2D Television
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Jun 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
