Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
How to reset 62dc1d? - RCA D52W20 52" Rear Projection HDTV-Ready Television
LG projection screen television model 62DC1D-AB switches on then keep switching off and the symbol looks like a flashing light globe what does this mean
Your LG HDTV is in protect mode that why you can see light .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted or leak capacitor in power supply section.
Regards:
votit
Feb 03, 2011 | LG DU-62SY20D 62" Rear Projection HDTV
Hi, i have a lg rear projection tv model no. 62dc1d-ab and i was wondering where i can buy a new lamp bulb for it, lamp number p22-hd5, lamp model as-lx60, 31419sn984a. And i also need directions in...
Make sure your TV is turned off at the power switch for at least half an hour. Undo the two screws on the lamp cover which is on the right hand side of the TV as you look at the screen.
Remove retaining screws on lamp case.Lift up fixed wire handle on lamp. Pull out knob slowly and remove lamp case. Insert new lamp gently. Tighten screws. Replace cover.Reset lamp time on menue.
Sep 10, 2010 | Televison & Video
Lg 62dc1d-ab rear projection tv. the picture has gone very darl even at full brightness
ure bulb will be on the way out go into the menu and there should be a lamp counter if its close to 8000 hours then its due for one, check ebay for cheapest price as they arnt under warranty
Sep 23, 2009 | LG Televison & Video
Tv turns off
My LG lcd tv did something similar, kept making a clicking noise every minute or so. In the end i took the back off and checked could see there was one popped capacitor on the power board. Replaced for £3 and has worked fine ever since. Hope this helps
Aug 30, 2009 | LG 37LC2D Television
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
