How do i clean a turboair GRO1R? - Heating & Cooling
Need service manual and parts book for TurboAir TAS-09
User manuals can be very tricky to get as various models usually have the same details for devices. Best way to get your user manual is to visit the customer support segment of the manufacturing company of your product website. From there check for your specific product and the user manual is most likely to be available for download free. Normally i would do a search for the product and send you the link but i might end up sending a different link.
Hope this solution has been helpful?
Apr 12, 2011 | Turboair Heating & Cooling
Hi, I have a Turboair Problem with the Turbo Air
Tried to find the code "CO" in service manual but to no avail and please furnish the proper model number as none you list appeal. You stated that the unit sat for 5 months so I am wondering if your unit has developed a restriction in the capillary tube as this unit uses R 134A which has this problem.
Nov 30, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
The remote just doesn't work
check the battery or battery terminal of your remote control.
Jun 30, 2009 | Turboair HG-002283 Split System Air...
M3 Turboair Refrigerator does not cool
http://www.turboairinc.com/TB-Service/Service.html#SANDWICH
Try this web site. It has you M3 listed with manual but needs exacting model number to get right one.
good Luck - Hope this works for you. If not, let me know.
Jun 27, 2009 | Freezers
Turbo air sandwich table too cold
Replace the thermostat which is located on the back of the unit underneath the bins in the very back. If the thermostat goes bad it will let everything just run and run and run. If this has been helpful please rate
Feb 12, 2009 | Turboair Turbo Air Sandwich Salad Table...
Turboair taw-12 missing grate
Try one of these supply companies, they've only failed me a couple of times.
http://www.wilmar.com/
CENTURY Maintenance Supply , 1-800-880-3416
Johnstone Supply, 1-800-493-4822
Maintenance Warehouse 1-800-431-3000
That should get you started. Hope it helps.
Dec 10, 2007 | Turboair TAW-12 Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
