Question about Moultrie Feeders MCG-12590 Game Spy Camera D-333
I can't get into the setup menu
I just replaced the batteries and now my cam won't take pictures. I've tried hitting the menu button over and over but the screen stays stuck on Motion PH 10SEC. What can I do to fix this so I can continue to get pictures?
When turned on screen is black but you can view menu and stored pictures
Since you can see the menus, did you try to go to the setup menu, and adjust the brightness of the screen?
It is in the setup menu, the line under Sound settings. Try to make the display brighter and don't forget to ok that one, because otherwise nothing will be changed. OK with the ok / Func button.
Jan 14, 2014 | Olympus FE-340 Digital Camera
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
I want to download pictures from the internal memory and I attached the camera with the usb cable and it does nothing. I've tried pressing the shutter button nothing
The only way is copy pictuers from internal memory to the external memory using the camera Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO-copies the current picture or video.
EXIT-returns to the Review menu.
ALL-copies all pictures and videos from your selected storage location to the
other location.
4 Press the OK button.
NOTE: Pictures and videos are copied, not moved. To remove pictures and videos from the original location
after copying, delete them
May 19, 2012 | GE X500 Digital Camera
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Sound without picture unit did not go thru auto set up input will not display
returned defective unit to the store after talking to them and determining the menu would not display.
Jan 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Instruction on zoom operation and also operation of flash on came
u have 3 problems here zoom,the flash and language ,ok to change the language hit menu .button then first word that shall be setup menu then word on the line number 3 and use right and left arrows to change ,the flash .turn the camera lens wheel on the pyramid sign u see on the front of the cam and then use the push button right side with zigzag sign to switch the flash mode ,push the button then up and down to zoom in and out
Mar 21, 2009 | Vivitar ViviCam 3750 Digital Camera
Moultrie Feeders MCG-12590 Game Spy Camera D-333 Logo
64 people viewed this question
Top Moultrie Video Cameras Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
