Question about Sole Fitness Exercise & Fitness
My sole e 35 says motor error
It has not been used much either almost new
  • 117 Answers
Check to see if the belt or rollers are jammed or stuck
Posted on May 10, 2014
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
Motor error messege on E25 sole ellipticle
proceed according. God bless youDescriptionThis error monitors the treadmills power bit reading. Power bits indicate the relative time that themotor controller drive circuit is turned on. Therefore power bits is an indication of the amount ofpower the load is demanding from the motor controller. The treadmill software sets a maximumallowable power bit limit. Error 25 indicates that the maximum power bit limit is being exceeded.Possible Causes1. The running belt and/or running bed is badly worn.2. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor filter capacitorcould raise the current demand sufficiently to cause the error 25.3. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor inductor couldraise the current demand sufficiently to cause the error 25.4. A shorted or de-magnetized drive motor is causing the high power demand.Possible Remedies1. A clamp-on A.C. ammeter must be used to determine the amount of A.C input current beingdrawn by the treadmill under no load and loaded conditions. The current readings can beused to determine the condition of the running belt and/or running bed. These same readingsshould be taken on a similar unit with a known good running belt and running bed. Thosereadings can then be used as a benchmark for future use. Replace the running belt and/orrunning bed as required. Remember, many running beds are double sided and the bed canbe flipped over rather than being replaced.2. A clamp-on ammeter should be used to measure the A.C. input current at no load. The filtercapacitor should then be electrically isolated from the drive motor circuit. The drive motorleads must be kept intact so that the drive motor will operate with the filter capacitor removedfrom the circuit. The no load A.C. input current should be measured again, if the A.C. inputcurrent is significantly lower, replace the filter capacitor.3. Use the same procedure as in step 4 above, except remove and isolate the inductor from thedrive motor circuit instead of the filter capacitor.4. A known good drive motor must be substituted for the existing drive motor.
Apr 02, 2013 | RTO Sole Fitness Package F85 Treadmill &...
F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
sincerely. God bless you
Apr 13, 2012 | Sole Fitness Sole F85 Treadmill
Error code of ls1 on sole f80 treadmill
John what are you talking about. All that's gonna do is give a LS error is you disconnect the motor.
Aug 22, 2010 | RTO Sole F80 Treadmill
My treadmill does not incline
incline motor has failed and needs replaced
Jul 17, 2010 | Sole Fitness F63 Treadmill
Belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Mar 12, 2010 | RTO Sole F80 Treadmill
Exercise & Fitness Logo
208 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
