Question about Refrigerators
How do you replace a defroster timer?
Frigidaire refrigerator model# FPDA18TPWZ. Cools ok, freezer not so good. This was in the house when I moved here (about three years ago) so I don't think it has a leak. Door w/strips look good, I checked for leakage with matches and none appeared.
  • Cliff Rechlin
    Cliff Rechlin May 10, 2014
    The real problem is the refrigerator runs a lot.
  • 117 Answers
Check the fan motor in the freezer and clean the coils
Posted on May 10, 2014
  • Cliff Rechlin
    Thanks for the input. The freezer fan runs and the coils are clean. My problem is the fridge runs a lot, that"s why I think it's the defroster timer. Any idea on how to change it? I think it's in the temperature setting box but I would like to know for sure before I start. Thanks again.
Gibson/Frigidaire GRS20ZRH - Refrigerator section does not cool. Freezer cools OK. Water and ice dispenser is OK. Model is a side by side. Underneath coil/compressor section is clean. Please advise....
Check your fan that goes from the freezer to the refrigerator. It is probably faulty. If not then check your defrost timer.
I hope this helps
Please rate me
May 27, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator doesn't work but the top freezer does.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 10, 2009 | Refrigerators
The bottom of my frigidaire is not cooling properly; and the freezer works great; is it a minor problem i can fix
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Frigidaire FRT17G4B Top Freezer...
Kenmore side-by-side freezer is fine but fridge is not
Yes, Airflow is what cools the frig. Check for frost buildup on the coils indicating a problem in the defrost components r a fan not running fast enough. Eric
Aug 18, 2009 | Kenmore 53092 / 53094 Side by Side...
Same symptom, freezer works... fridge doesn't, and its frozen
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator cools fine but the freezer does not. It stays at about 20 degrees f. It is a GE
Aug 16, 2009 | Refrigerators
My freezer is freezing great, the fridge is not cold at all! Just moved fridge into my house yesterday, bought on Craigs list
the freezer actually cools the fridge via a fan usually located in the "ceiling" of the fridge. make sure this is working and check yur temp contols make sur they are adjusted right
Aug 16, 2009 | Frigidaire FRT18G4A Top Freezer...
Frs28zrg leaking. frozen water in bottom of freezer. drips on inside of fridge/freezer. water/ice not working....should I attempt to fix this or pay $100 for my home warranty repair...
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model clean drains
Aug 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire FFU20FC6AW7 is not freezing. sides are cool to the touch and they are normally hot. cold air blowing out about 40 degrees.
How to check stuff>
Jul 12, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Help in North Carolinia
if you look inside the freezer you will see frost on the back panel of the freezer, you ar defrosting manually, the issue is either a defrost heater a defrost therinastat or a defrost timer, the timer is an adaptive defrost timer and is in the fresh food section of the ref, gut feeling is defrost timer but one of the three, a ohm meter will tell you if the heater and the thremastat are good if so the timer is the problem
May 20, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
