Kenmore special edition washer model 4766294 will not spin,any suggestions?
  • Washing Mach... Master
  • 2,344 Answers
Here are two things to check. First is the lid switch. If it is broken or stuck it will not tell the timer not to spin the clothes. A new one will fix that.
Second, is the coupler. If you tirn the machine on its side and look underneath, see if the coupling between the motor and the transmission is broken. If that is the case, a new coupler will solve the problem.
Be blessed.
Posted on Jun 23, 2014
2 Suggested Answers
  • 884 Answers
SOURCE: My kenmore special edition dryer works but doesn't
Thermostat or element suspect
Posted on Apr 21, 2012
Old top load washer Kenmore special edition 1104766392 washer leaks when in agitate and really bad in spin cycle. Believe its a seal. Please answer and tell me where I can find a parts breakdown.
Probably best to get a new one. If it's old, you could have a rusted out tub, if not and it is just a seal, they usually all should be replaced, and older washer parts are getting harder to find. So many new models come out every year.
Jan 04, 2015 | Washing Machines
I would like to know the year of my Kenmore special edition washer and dyer SM 97 10804-4
Hi C,
Looks like around 2001 according to Serial #.
110 prefix means Whirlpool manufactured this item for kenmore
Dec 29, 2014 | Kenmore Washing Machines
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
My kenmore special edition will not spin
What is the model number of the unit?
Nov 29, 2012 | Washing Machines
Kenmore Special Edition Top Load Washer - model # 24692300 - clothes are still quite wet following spin cycles. Machine appears to spin at a reasonable speed. HELP!!.... Thanks
Hi, Could be as simple as a slipping belt, they can get glazed, stretch or even get wet small water leak, and get the tub spinning but not fast enough or taking to much time getting going fast that the washer timer says it should be done and goes into the next mode. If you have no Idea how to repair the belt or check by looking under the machine after you unplug it, the only help is the repair person.
Nov 23, 2011 | Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
WASHER WILL NOT DRAIN WATER KENMORE WASHER APPROX 9 YRS OLD
Does the tub spin without draining?
This JUST happened to me last night. Opened washer after a load and still full of water. Fifteen spins later, still about an inch of water in tub...
RepairClinic.com suggests checking the hoses from the washer tub to the drain pump for anything clogged in it. (WARNING!!! As soon as you remove one end of the hose ANY water remaining in the tub will come RUSHING out if not clogged. I was prepared for water, but not a rush of water.)
If there is no clog in that hose, remove the drain pump and check for something in it.
(My pump was burning up because some how a plastic stick got into it. I am waiting on the new pump now.)
If there is nothing in the first hose or the pump, see if anything is in the hose leading to the drain.
If not, they suggested something either purchasing a new pump as it may have quit working or something may have gotten stuck in between the tubs. This requires tearing apart and sometimes special tools.
Jul 15, 2009 | Kenmore Washing Machines
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
