For the last few days, the Express Freeze button sounds is on and off almost every 5 minutes, then it will stop and tonight it went on and off for few hours, minutes apart from each beep. Tried to see maybe the airflow if covered, re-arranged everything in the freezer compartment, however, it still beeps from time to time. Would anyone know of this problem, or what would I check before asking someone to come and check it. Thank you for all your attention and I much appreciate everyone's help.
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
SOURCE: The alarm beep which tells you to close
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
SOURCE: Fridge sat turned off for
Hi.
Try disconnecting power cord for ten minutes (turning off is not enough). See if that does reset the fridge.
If that does not help, then check if there is ice forming in evaporator coil at the back of the fridge. Eventually wait one or two extra day. If ice starts forming and fridge quits cooling, then you have a problem with the defrost system. Likely the thermostat or the defrost timer.
IF the unit keeps cooling regularly, and defrost is OK, then it may be a disconnected temperature sensor. This will cause beeping, and fridge cooling regularly.
About defrost control, see this article: When the fridge is not cooling ...
To find parts and diagrams enter the model number in the links listed below, try all the links listed:
Where do I find parts and diagrams?
If you need to contact a technician use the Fixya directory (US only).
Regards.
Ginko.
SOURCE: every hour or so the
Hi, If you are hearing a clicking or buzzing then check out the last two tips.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
