Bosch maxx 900 manual
My bosch maxx classic 900rpm front loader washing machine keeps tripping out our power ?? No obvious power lead problems! It seems to be coming from with in the machine! Grrr! I am a rural woman on my own and would really appreciate any help or advice on this matter...I would also appreciate a workshop manual ? Cheers! Alannah
    Problem Solver:
  • 7 Answers
It could be caused by a damaged heater element.. remove and check for damage. One way to check is to remove the two wires and tape up to prevent accidental short circuit. set machine to a cold wash if it does not trip you know what you have to replace. if it still trips then remove the motor and check carbons/ brushes for excessive wear. good luck..
Posted on May 10, 2014
SOURCE: I cant find a manual
YOU SIMPLY SEARCH ON GOOGLE.COM OR ASK.COM TO COPE OUT WITH THIS PROBLEM.
Posted on May 02, 2008
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
  • 6277 Answers
SOURCE: Bosch Maxx 900 front loader
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 21, 2011
  • 6277 Answers
SOURCE: I have a Bosch maxx
I suspect that there is water still left inside as the drain pump has been unable to complete its task so they are being spun in water!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Sep 19, 2011
  • 1527 Answers
SOURCE: why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
Posted on May 17, 2012
How do I find clean the filter of our bosch maxx classic 900 rpn front loader? I can't even find the filter.
Filter is located bottom left of machine it has a small black hose tucked inside ,you would remove the Plug on the end of the hose and drain any excess water into a container then unscrew the filter anticlockwise to remove the filter any object within will now bw apparent... Good luck.
Feb 16, 2015 | Bosch Washing Machines
How do I find clean the filter of our bosch maxx classic 900 rpn front loader? I cant even find the filter.
You don't. Washing machines don't have a handy accessible filter...
Check the owner's manual that came with the machine.
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
regards
shaun
May 17, 2012 | Washing Machines
How do I wash delicates, which drawer, what soap or detergent, etc., front loader Bosch machine, bought recently, (lost manual).
WAE18060AU im leaving this on this page becuase it is a model number to a maxx classic the look up site is currently down for maintenance ill message you back in about 6 hrs Rick
Jan 15, 2011 | Washing Machines
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
439 people viewed this question
Top Washing Machines Experts
