Question about Samsung LN40B530 40 in. LCD HDTV
Why is my samsung ln40b530 picture color start to change into negative colors after its turned on for a few minutes? to turn negative
White frame forms around the screen and the color is negative and gets worse the longer the tv is on
lukster
  • 217 Answers
SOURCE: Green shadowing on Samsung LN-S3251D
sounds like you need a service call if it's in warranty, if not in warranty, you may need to have the logic main board replaced
Posted on Apr 30, 2007
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
SOURCE: Turn on Samsung LN-T4665F and vertical colored
when I turn the modelLN-T4661F TV on it just clicks and clicks any help how to fix it.
Posted on Nov 29, 2009
toolkits
  • 1099 Answers
SOURCE: I have no color on my Samsung Flatscreen TV
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Posted on Jun 14, 2010
SOURCE: Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Posted on Jan 03, 2011
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
After the tv has been on for about 30 minutes the picture starts flickering really bad and eventually will go completely white like where it looks kind of like negatives? it works perfect for that first...
The colors wheel could dies at any time of the tv life,at any monent without any period of times.The colors wheel run at RPM spinning revolution are 1000 RPM a min. to make colors for this tv.The problems u discribing are one problem of the effect of the colors wheel is dying and worn out.The colors flashes like film negative,the picture flashes Black&White withtin the picture.Replace the colors wheel again,will solved this problems.
Nov 20, 2010 | Samsung HLN617W 61" Rear Projection HDTV
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Black and white screen...
The color wheel can cause a black and white picture but not the jumpy or negative look.
Those symptoms are usually caused by the DMD assy which drives the color wheel and is somewhat expensive, most of the time you can purchase the whole Light Engine which includes the DMD assy for the same price.
Mar 20, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Picture looks like a Colored Negative
so, how can i fix this problem with my tv. the tv comes on but the colors look fuzzy..help!!
Oct 27, 2008 | Syntax Olevia 50" Rear Projection...
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung LN40B530 40 in. LCD HDTV Logo
80 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
