Question about Waring WMK300A Waffle Maker
How to replace fuse - Waring WMK300A Waffle Maker
  • 117 Answers
Bad news it does not have a fuse. you may have a broken wire to the temp control, heat element or a bad cord. If you do find any of those things. it's time to get a new waffle maker.
Posted on May 10, 2014
  • ps6155 May 13, 2014
    That you didn't know every waffle iron sold in the US is required by U: to have a thermal may be bad news - FOR YOU. I found replacement 240 degree thermal limiting fuses on ebay 4/$2.
Blown fuse on fuel pump 1996 Ford explorer Replaced fuse drove vehicle home. Now it will not start.
A blown fuse is an indication of circuit overload. Did you replace the fuse with one of the same value or higher? is this the standard current rating for that circuit (usually marked on the fuse cover.
If the engine cranks remove a spark plug tape it to the intake manifold or somewhere where there is clean bare metal (please not near the battery) check for spark if ok reinstall plug if not replace the ECM fuse and relay with alternatives in the fuse box if this gets the pump going replace the ECM fuse and or relay then check for fuel turn on the ignition you should hear the pump run and then shutoff if not replace the pump fuse and relay with alternatives in the fuse box if this gets the pump going replace the pump fuse and or relay
Feb 11, 2016 | Ford Cars & Trucks
Replacing 140 amp fuse in lexus gx 470
Replacing 140 amp fuse in lexus gx 470 - Fixya
www.fixya.com/.../t26021201-replacing_140_amp_fuse_in_lexus_gx_4...
24 mins ago - The battery in my lexus gx 470 needed to be replaced it was hooked up wrog and the 140 amp fuse was blown how do i replace the 140 amp ...
HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS ...
www.fixya.com/cars/t24496313-replace_140amp_fuse_lexus_gx470
May 24, 2014 - HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS GX470CAN"T GET THE FUSE BOX APART TO UNBOLT THE FUSE - Dodge 1997 ..
Dec 25, 2015 | Lexus GX 470 Cars & Trucks
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Show how to replace power outlet fuse for 2006 Toyota Camry
Interior Fuse Box Location 2002 2006 Toyota Camry 2006 Toyota Camry LE 2...
The video above shows how to replace blown fuses in the interior fuse box of your 2006 Toyota Camry in addition to the fuse panel diagram location. Electrical components such as your map light, radio, heated seats, high beams, power windows all have fuses and if they suddenly stop working, chances are you have a fuse that has blown out. If your Camry is experiencing electrical problems, you should always check the fuses first, because they are relatively easy to check and cheap to change. Some Toyotas have multiple interior fuse boxes including in the trunk - the video above will show you where the interior fuse box of your 2006 Camry is located. If your Camry has many options like a sunroof, navigation, heated seats, etc, the more fuses it has. Some components may have multiple fuses, so make sure you check all of the fuses that are linked to the component in question.
If you need to replace a blown fuse in your Camry, make sure you replace it with one that has the same amperage as the blown fuse. If checking and replacing the fuse for the component in question doesn't work, we recommend seeking assistance from a trusted professional mechanic. They should be able to figure out if the component needs to be replaced or if there is a short or some other problem with your Camry.
Good Luck
Feb 22, 2015 | 2006 Toyota Camry
Black decker bna17 mini fridge
I am having the same problem. Replaced the fuse with fuse holder and 3A fuse but the new fuse blows immediately. What do the diodes look like? and how do you replace them?
Sep 19, 2013 | Refrigerators
Fuse panel diagram
Fuses
Print
REPLACEMENT
See Figures 1, 2, 3, 4, 5, 6 and 7
Fig. Fig. 1: The power distribution box in the engine compartment contains fuses and relays
Fig. Fig. 2: Remove the cover for the interior fuse panel
Fig. Fig. 3: A fuse puller tool is located inside the fuse panel to aid in the removal of the fuses
Fig. Fig. 4: Grasp the fuses with the puller and pull straight out to remove the fuses
Fig. Fig. 5: There are generally four types of fuses used in these vehicles
Fig. Fig. 6: Fuse current rating and color code chart
Fig. Fig. 7: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made
Fuses protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity.
If a fuse blows, the cause should be investigated and corrected before the installation of a new fuse. This, however, is easier to say than to do. Because each fuse protects a limited number of components, your job is narrowed down somewhat. Begin your investigation by looking for obvious fraying, loose connections, breaks in insulation, etc. Use the techniques outlined at the beginning of this section. Electrical problems are almost always a real headache to solve, but if you are patient and persistent, and approach the problem logically (that is, don't start replacing electrical components randomly), you will eventually find the solution.
Each fuse block uses miniature fuses (normally plug-in blade terminal-type for these vehicles) which are designed for increased circuit protection and greater reliability. The compact plug-in or blade terminal design allows for fingertip removal and replacement.
Although most fuses are interchangeable in size, the amperage values are not. Should you install a fuse with too high a value, damaging current could be allowed to destroy the component you were attempting to protect by using a fuse in the first place. The plug-in type fuses have a volt number molded on them and are color coded for easy identification. Be sure to only replace a fuse with the proper amperage rated substitute.
A blown fuse can easily be checked by visual inspection or by continuity checking.
The fuse block is located on the lower left side of the instrument panel. To access the fuse panel, open the driver's side door. Pull off the fuse panel cover to get to the fuses. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
REPLACEMENT
  1. Locate the fuse for the circuit in question.
When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating.
  1. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
  2. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse
Aug 10, 2012 | 2000 Pontiac Sunfire
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
I bought my car used from someone and it didnt come with the owners manuel and the cover of the fuese box is missing so i need to know which fuses r wich!! plz help
REPLACEMENT
  1. Locate the fuse for the circuit in question. NOTE: When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating. On some vehicles, you may have to remove a cover for access to the main fuse block 88256p51.jpg
    The fuse panel cover has a label with the fuse designations on it 88256p52.jpg
  2. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse. Locate the fuse which needs to be checked . . . 88256p53.jpg
    Fig. 1: Fuse locations and component identification 88256g71.gif
    Fig. 2: After you pull the fuse from the block, check the element 88006p42.jpg
    Fig. 3: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made 88006g76.gif
  3. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
Jul 14, 2010 | 1996 Chevrolet Corsica
2002 Mercedes C320 wagon / fuse for cigarette lighter
Just did this on my 2002 C320. The blue 15 amp fuse is located in the front fuse box under the hood. It is either #47 or 48. If you already opened the driver-side fuse box, see if the paper fuse map is still there. If it is, find the fuse to be sure. Replacement is very easy, but there is a fuse puller tool in the spare tire well where your kit of replacement fuses should be. if you are in luck and you have a replacement, use the puller tool and replace the fuse.
Mar 02, 2009 | NAD C320 2-Channel Amplifier
Waring WMK300A Waffle Maker Logo
90 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
