Question about Husqvarna 20HP Hydrostatic 42" Cut Riding Mower
Why does my husqvarna riding tractor motion belt keep slipping off the pulleys?
    New Friend:
  • 3 Answers
They did not manufacture the pulley correct. The pulley lip is to short. What u need to do is bend the belt keeper so it just touches the belt on the idler pulley. I remove the pulley and keeper and give it a good bend. Then I adjust it into the correct position after reassembly. It doesn't have to rub on the belt.... just very close. That will do it.
Posted on May 10, 2014
2 Suggested Answers
  • 3911 Answers
SOURCE: My Motion Drive Belt slipped
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Posted on Sep 11, 2011
I need to know the placement of the deck belt on my husqvarna mower 26k54t. I think I keep twisting it the wrong way, which pulleys need the flat side of the belt on?
https://www.partstree.com/parts/husqvarna/mowers-lawn-garden-tractor/gth-26k54t-96043001101-husqvarna-garden-tractor-2006-03/mower-deck/
Sep 09, 2016 | Husqvarna Garden
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna problems
check and see if belt rolled off pulley or broken belt next check pulley for alinement then check and see if you have split pulley 1 month is about the time it would take for the belt to stretch make sure your tensioner is working for the belt give that all a try
Aug 19, 2014 | Husqvarna 24HP 54" Yard Tractor ()
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The motion drive belt on my husqvarna yth2348 keeps coming off rear pulley above the transmission.
it sounds like an alignment issue check guide pulleys and make sure their not damaged or bent also check for broken parts
Sep 03, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have the Husqvarna LGT2554, with les than 30 hours. The drive belt slips off all the time. I have put it on 5 times and nnow purchased a new one and just put that on. I did 4 swipes and it slippped...
THERE SHOULD BE GUIDES, THE LOOK LIKE LONG BOLTS THAT ARE NEXT TO THE PULLEY, THESE NEED TO BE CLOSE TO THE PULLEY TO HELP KEEP THE BELT ON WHEN THERE IS DECK MOVEMENT ,. MOWER OFF , DECK DOWN AND ENGAGED.. SIT THERE AND STARE AT THE BELT AND PULLEYS TO MAKE SURE THERE ALL LOOK LEVEL AND TRUE, THE TENTIONER BRACKET CAN GET BENT EASILY. THIS IS WHAT I HAVE FOUND
Jun 17, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Hi,was rolling my lawn with a yth2454 husqvarna.i released then pushed on drive pedal and it wont move.i replace the motion belt now it moves but barely.the old belt was stretched.also now there is a...
hay
it sounds like the new belt you fitted neads more tension on it find the tension pully again and get that belt a bit tighter make sure that you can get it tight enough not to slip!!!!
good luck
andrew
May 01, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Drive (motion) belt has come off the rear pulley twice in a month
husqvarna yth20k46
drive belt came off
fix
transmission boltes were not installed
replaced fix problem
Jul 16, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
The motion belt keeps coming off the pulleys this ( Murry )
I think you need a new belt. maybe it's stretched to much now this will make it slip of. also clean the pulleys maybe oily or something.
Jun 10, 2009 | Garden
Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Logo
93 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
