Question about Electric Lawn Mower
Where can I find directions to replace the switch in the handle?
I have the same problem blumph had! Used it approx 5 times...twice last year and twice this year, so four. Started great, and cut twice, then when I recharged it.....poof....nothing. The battery shows it's fully charged but the handle charge lit red, no charge and a slight hum at first, then dead as a door nail. Called Homelite # after having to search online! as the manual gives a wrong #. Basically I need my receipt, which I can't find to send to repair shop. I saw this answer and was like....great, I can do that, but honestly I need to know what to do. I can't afford to go spend another 300.00 on a mower, and I'm really disappointed..to say the least....that it already died on me! Please, any suggestions would be great.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Batteries dies if they are not charge in time atleast one per every month either u are using it or not
Posted on May 10, 2014
3 Suggested Answers
SOURCE: I have a problem with a Black and Decker electric
Hello blumph,
I can think of only one or two things that are causing your problems. It could either be approx. a $14.00 switch in the handle that has shorted out, or 2 bad brushes $1.75/ea.on the armature (motor). Both are fairly simple fixes with just a screwdriver and maybe pliers. You might also check and see if the power cord has been chafed or damaged and is shorting out.
See below for parts:
http://www.ereplacementparts.com/black-and-decker-mm575-electric-lawnhogtrade-mulching-mower-parts-c-4167_9514_9550.html
yurcarguyken@yahoo.com
Posted on Oct 07, 2009
  • 603 Answers
SOURCE: TORO 20074A Starter not working.
OK seems to me you have a connection problem. This doesn't always mean that a connection where two wires plug together is bad. It could be a problem as simple as a mouse chewing thru a wire.
Take your time and check the wire or wires that go from your battery down to the starter.You may very quickly find your problem. A bad contact, a broken wire, a disconnected wire, or that bad little mouse, which will lead you to the purchase of a mouse trap before he causes you any additional headaches. GOOD LUCK.
Posted on Jul 05, 2011
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
I purchased the wndchaser mistingfan approx 2 yrs ago. It doesn't work after having been used a few times. The switch doesn't work to turn the fan on. I tried to contact the co by phone to no avail
It probably is out of warranty. Most warranties last no longer than 1 year. The switch needs replaced. But it would be cheaper to buy another brand of fan than to pay someone to repair the one that you now own, unless you do the repair yourself.
Jan 03, 2014 | Windchaser Outdoor Misting Fan WC161 Stand...
1998 Pontiac Grand Prix GT - Blower Motor will not blow in the lower speeds, High Speed (5) only. Resistor has been replaced 3 times in the last twenty four hours, blower motor has been replaced twice in...
Your ignition switch is bogus. High speed runs directly off the speed control but the lower speeds go thru the ignition switch. Do not know why but that is the way it is!!!!!!!!
Replace the ignition switch and you will be back in business.
Jun 20, 2017 | 1998 Pontiac Grand Prix
Tv has no picture or sound. replaced bulb no help greenlight blinks 79 times. red lights start blinking
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a problem with a Black and Decker electric lawn mower model MM525. While cutting some high grass today, the mower slowed down, then quit and would not restart. I checked the electrical outlet and...
Hello blumph,
Oct 05, 2009 | Electric Lawn Mower
Need manual for t14 gardena water timer 12 yrs old approx
Program Cycle Duration (minutes)
man On Once 30
1 4 times a day 3
2 Twice a day 3
3 15
4 Once a day 3
5 5
6 30
7 60
8 Every 2 days 5
9 30
10 60
11 Every 3 days 30
12 60
13 Every 7 days 60
14 120
Can't believe I saw this...don't usually go on the hunt on the net, but wanted to see if I could source some more of these. I, too, have had my timers for 12 years and swear by them...Excellent product...just happened to go out to the shed today and found the last surviving box, with instructions !!! Good luck, Fiona
Jan 16, 2009 | Hardware & Accessories
Idling problems with 2007 GSXR 600
check fuel switch, is it on? most times the fuel from the last ride that wasnt used collects in the fuel bulbs, and gets used first, but after that no fuel no go!
Dec 24, 2008 | 2007 Suzuki GSX-R 1000
2004 Chrysler Crossfire
I have no idea if this is a common fault with the model of car that you have. I would check this out. It is obvious at this point the necessary parts will have to be replaced to fix the fault. The parts used in the steering system and the labour to do the service work can be very expensive.
I would find a reliable private garage that works on the model type of your car to have another opinion and estimate.
Jerry G.
Nov 21, 2008 | 2004 Chrysler Crossfire
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
Electric Lawn Mower Logo
65 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
