Question about Bosch Dishwashers
How to replace Bosch fascia panel 00665887?
The fascia panel on my Bosch dishwasher model SHE55M15UC/60 needs replacing,I have the part, how to proceed?
5 Suggested Answers
  • 1314 Answers
SOURCE: Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
send me an email at b4829@yahoo.com and ill send inst
Posted on Mar 19, 2008
  • 246 Answers
SOURCE: Are white front door dishwasher replacement panels available?
Absolutly! There is a website that allows you to do a bunch of stuff to the front of your dishwasher , including changing colors, without actually unscrewing anything. Check out www.applianceart.com. They do sell stainless metal panels for cheap there too.
Posted on Nov 12, 2009
  • 246 Answers
SOURCE: Need to change color of front of dishwasher
Try Applianceart.com. They have a ton of options in colors and desings
Posted on Jan 14, 2010
  • 246 Answers
SOURCE: need new dishwasher replacement door panel in
you should also look at www.applianceart.com. They have a ton of replacement panel options for the front of the dishwasher to change the appearance. Black white, stainless, but also picutres, designs, and lots of options.
Posted on Feb 04, 2010
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
SHE33M Built-In Dishwasher handle broke off?
You have not put the full Enr, but from the bit you have added I assume you are in the states. I think you should be able to get parts from
http://www.searspartsdirect.com
Usually if the control panel breaks on this model, it is because you have the child lock activated on the door latch inadvertently and therefore have to force the door to get it open. This in turn puts stress on the panel which will eventually break. When you get the new panel ensure that you remove the child lock from the door latch. If you take off the front fascia panel and look at the door latch (centre top) you will see a yellow lever attached to it with a spring, just pop this off and you will immediately find that the door is much easier to open.
All the best.
Apr 18, 2013 | Bosch 23 in. SHU33A Built-In Dishwasher
Replaced the control board in Bosch Dish Washer SHE44C and the cycle times are reversed???
I think this board requires coding to your particular model?? your dishwasher has four selection button and a delay start, whereas the module has five selections and delay as it is used in several different modesl. The coding info should have been in the box with the part and may need to be carried out directly on the module with the fascia panel removed. If you post the part number of the module I will see if I can get you the coding information..
Mar 01, 2013 | Bosch Dishwashers
The start button will not stay pushed in
Hi
The start button, tends to fail on some Bosch Dishwasher models. The spring mechanism fails.
You can order the ON/OFF switch and replace it.
You need to disconnect the machine from its power source and open the control panel via hex screws. You may also need to open the front panel screws to get the top panel off.
Bosch dishwashers can be tricky and when you open the panel you many need to undo some latch tabs to get to the on/off switch.
Note the wiring on the switch before replacing.
If you thinks this solutions helped, please give 4 thumbs up.
Sep 21, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Can I continue to run my dishwasher with a broken
It is not advisable as if the door is even slightly open you will get damp and steam condensation entering the fascia panel which will eventually blow the module. Bite the bullet and change latch rather than an expensive control module.
All the best.
Jul 09, 2010 | Bosch Dishwashers
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Looking for a video on how to make and install a custom door panel for 18" bosch dishwasher
no video but it is easy to do .take off screw around the door and replace panel insulation on some model and replace panel.
Feb 23, 2010 | Bosch SRV53C03UC Built-in Dishwasher
Dishwashers Logo
496 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
