Question about Dishwashers
We have an asea cylinda 1250 dishwasher that gets stuck and doesn't clean the gease off the dishes
Could it be that the element is not working? - Is it possible to get a replacement? And a copy of a manual?
3 Suggested Answers
SOURCE: User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Posted on Jul 05, 2008
jyackle5
  • 8197 Answers
SOURCE: manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Posted on Apr 24, 2010
Need a timer motor for asea cylinda 1200 dishwasher.
Standard appliance parts, Appliance parts incorporated, even Sears will have parts available generally.
Nov 09, 2015 | Dishwashers
Asea Cylinda 1400 dishwasher not filling. Keeps waiting for water to fill. Continues normally if manually add water. Tap is on and water available.
The incoming water valve is faulty. Look at the back of the machine where the hose connection runs into the machine, there should be a solenoid operated water valve there. Check that out or replace it.
Dec 05, 2014 | Dishwashers
Asea cylinda
go by manual so you dont mess up
Aug 08, 2013 | Dishwashers
OUr ASEA Cylinda dishwasher doesn't seem to have any power. The manual suggests the fuse might be blown. THe circuit breaker is fine. Is there a fuse on the machine that can be replaced?
You need to trace the power cord into the machine to confirm this case. It will lead you into the circuit and if power is not present to the controller section there can be a fuse before the circuit.
Remove power to the machine and remove panel to check.
Jan 24, 2013 | Dishwashers
Dish washer does not clean dishes very well and leaves a grainy residue stuck to dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Nov 30, 2010 | Bosch Evolution 500 SHE45M06UC Built-in...
Manual for Asko ASEA 1400 dishwasher
Apr 24, 2010 | Dishwashers
Asea skandia cylinda 1200 manual
Dear Sir!
After almost 27 years since when I bought dishwasher machine type Cylinder 1100(during my post graduate of doctor engineer training - work in Finland haveproblem with manual programmatic. Because we have no chance to find in Poland,I would like to ask about possibility to buy and import it. If in case when itis similar like at Cylinda 1200 so I could update it. In the same time I coulduse and connect by adapting existing electric wirings. Please be so kind and help me solvingproblems. I am very satifited from good product done by your company. It is forme and my wife very urgent. Other way I will have only way to make all work inkitchen me. If you decide, please present quotation and all information fortransferring many. Best Regards
dr eng. Roman Lamentowicz.
roman@krola.com.pl
+48 602 211 746
Oct 16, 2009 | Dishwashers
Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Sep 30, 2009 | Dishwashers
I push the start button on my Asea Cylinda 1500 dishwasher and nothing happens. Could it be the solonoid?? If so where would I find it so I can replace it?
Had the same problem. After years of opening and closing there is a risk for one or two cabels to be cut inside the door. Easy to fix.
Apr 13, 2009 | Dishwashers
Apr 25, 2008 | Dishwashers
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
