Question about Whirlpool PUR Ultimate Refrigerator Water Filter 4396710
How do you remove a 4396710 Whirlpool filter that's jammed in the refrigerator?
We have a Whirlpool refrigerator and use the 4396710 filter. My husband went to change he filter tonight and must not have had it lined up properly as it's now stuck. It doesn't seem to be in all the way, but we can't get it to go in any further nor can we get the filter out. It's jammed in there. Any suggestions on how to get the filter out?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Posted on May 10, 2014
Testimonial: "We know how to change the filter! However, its somehow stuck in there and we can't get it out. We need to know how to remove it if the release button isn't working."
Water filter in whirlpool refrigeratoris stuck and cannot be removed
http://www.partselect.com/Refrigerator+whirlpool-filter-removal+repair.htm
Aug 26, 2016 | Whirlpool WRF736SDAM 26 cu. ft. French...
How do you change the water filter?
Which Whirlpool model do you have?
I know the ED5KVEXVQ has the filter in the grille nearly centered on the freezer (left) side of the unit. This is the P2RFWG2 or 4396841 filter. Push the button until the filter pops out. Take the cap of the end of the filter (the side that was even with the grille) by twisting counter-clockwise. Take the new filter out of the box and put the cap on the appropriate end (twist clockwise). Take off the red caps from the other end. Insert the filter into the opening with the cap to the outside and press firmly until it clicks into place.
The other common Whirlpool refrigerator filter is the 4396710. This installs the same way except it doesn't ship with a cap that you need to remove on the one end.
I hope this helps.
Dec 13, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Am attempting to change an in grill water filter for my whirlpool side by side fridge, and cartridge seems jammed, cannot turn anti-clock wise to release. Do not want to force in case I break it. Any...
Use one wrench to hold the water line and another one on the filter to avoid braking the line, the filter should give up.
Don't forget to rate this post!!
Sep 19, 2010 | Whirlpool GS6NBEXR Side by Side...
I have a ED5PHEXRQ00 refrigerator. The red light
Your filter is located in the grill of the refrigerator (below your doors) and has a small plastic "handle" or "knob" on it. Turn the handle counter clockwise so that the line of the handle points up and down and pull out the filter. Save the handle to slide onto the new filter. I also believe that you will need to press the light switch in the refrigerator five or six times to re-set the filter status.
Filter is part number 4396710
Jun 27, 2010 | Whirlpool Refrigerators
Replaced a waterfilter in my ref with wrong filter model
The new filter you used will not damage anything in the refrigerator, the only difference will be in the fill rate, it may fill slower than you like.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can't find filter #4396711 in lowes but can find #4396710
Does it say it fits both? Kenmore makes universal filters to fit all models...try sears dot com
Mar 20, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Cant make the water work
There is no link between the filter and the light, that light runs off of a timer. Take the filter back out and look at the housing that the filter goes into, some models have a little button that gets pushed in by the filter, it is a mechanical stop to prevent water flow with no filter in place. Do you hear a clicking noise when you attempt to get water out of the unit?
Jun 15, 2009 | Refrigerators
Need to change the frig water filter
filter part number is fsp-4396710 @$39.95 it is located in the front grille on the left side. It unscrews and pulls out. You transfer the twist top onto the new filter and push and screw it back in.
Apr 08, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hange filter
your filter is located in the front kickplate just below the freezer door. to replace filter push in on the button to the left of the filter cartridge (its a semi triangular button) push in until the filter releases. remove the endcap from the filter and reintall it onto your new filter. in case you need it here is the part number 4396710 it can be purchased online or at any home depot lowes or sears store. good luck and thx ofr using fixya.. peyton...
Jan 28, 2009 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool PUR Ultimate Refrigerator Water Filter 4396710 Logo
335 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
