I have a supersonic SC -1326 tower speaker. I won it in a raffle and it worked for the first day. The second day the USB port on the front face stopped working. Then the mode button and the EQ button stopped working. The next day the tower would not power up.
  • 29 Answers
SOURCE: Speakers not working, but cables all plugged in...
No drivers for your soundcard, this is a computer issue not a speaker issue, contact dell, if you can understand a word they say, ask them "I have Dimension (model number here), I need to know how to install my sound drivers", if you dont know how to do this.
Posted on Aug 12, 2006
devocap
  • 201 Answers
SOURCE: Desktop PC...Compaq Presario SR1010V Dont work
Hey there suepike, there are several steps you should take to check the status of things on your computer. I will give you a site address to guide you through some troubleshooting for your machine. Scroll down to the section that applies to your situation, with power supply on or flashes.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=448452&lang=en&docname=bph06788
If the link does not work, just copy and paste to browser. I hope you find the answers you need. Good Luck. Please reply back with what you have discovered if you need further assistance.
Posted on Feb 04, 2008
Drummernick
  • 440 Answers
SOURCE: Dell Dimension 5100
buy new power suplly for it ok
Posted on Feb 11, 2008
renosean
  • 492 Answers
SOURCE: Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Posted on Mar 07, 2008
MDoe
  • 156 Answers
SOURCE: Dell Optiplex GX260 Tower flashing yellow power button
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Posted on Mar 27, 2008
Hod do I factory reset my karaoke player
CAVS USA User Forum - H...
cavsusa.com/kb/index.php?action=sitemap&letter=H&lang=en
How do I reset my player to factory settings? ... How to make a karaoke songbook file from an external hard drive on a 203G USB After preparing the external ...
CAVS USA User Forum - W...
cavsusa.com/kb/index.php?action=sitemap&letter=W&lang=en
Reset the players to factory defaults. *Defaults will ... Why don't I ... Why will my new [model] karaoke player not play SuperCD+G discs? SuperCD+G discs play ...
Supersonic SDAT SC-25 DVD/Karaoke Player Factory reset ...
www.fixya.com > ... > Supersonic SDAT SC-25 DVD/Karaoke Player
Supersonic SDAT SC-25 DVD/Karaoke Player, factory reset button related issues. ......reset my pioneer dv 490v to factory setting here is the link to your manual: ...
Acesonic DGX-109 USB Multi-Format Karaoke Player with ...
Dec 06, 2015 | Televison & Video
How do I access my USB to view my photos?
Teri
I am assuming you are asking how do I access my USB memory stick photo files that I have plugged directly into the usb port of my SC-3211 32 8.5ms led television.
answer based on my assumption - you need to find on the remote control a select input source button and change the input source of the tv to look at USB port
Sep 28, 2015 | Supersonic Sc-3211 32 8.5ms Led 1080p
I need a universal code for a supersonic dvd player SC-170
Lets see what do i have stored in my head??? Hmmmmm nothing look in the book
May 24, 2015 | Supersonic Sc-178 7 Portable Dvd Player...
I have a supersonic dvd player and it won't spin at all.Model no sc-178 dvd
sorry to say but most likely case is bad motor or turntable issue of some type. unless expensive unit cheaper to buy a new player.
Nov 03, 2012 | Televison & Video
My SuperSonic TV combo want reconize my USB drive
Contact the company for a solution. or go to their web site for answers.
Mar 13, 2010 | Supersonic FC2245 13 Color TV/DVD Combo...
I am unable to get all of the speakers to work. I
Depending on the source, you typically only hear program material from the three front most of the time. Ensure that you are using surround encoded source material or try changing surround modes.
Aug 11, 2009 | Supersonic SC-36HT System
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
47 people viewed this question
 Grubhead
Grubhead
