Question about Gestetner 3502 / 3502P / 4502 / 4502P / P7145 Copier Machines 89856 Type 3502 Black Toner Bottles 4/Pack 3841
Where is tha waste toner on a gestetner 3502p?
4 Suggested Answers
newport74
  • 58 Answers
SOURCE: can't find the toner waste bottle to empty it for
It is located in the transfer belt assy.
open the right door look for the brown belt assy
lift lever and remove
remove front and rear springs
spread clips and swing belt assyup from case assy and remove
remove three blade screws remove blade and set aside
slowly dump waste toner
reverse procedure to reassemble message should clear (nothing to reset)
Good luck
Posted on Apr 15, 2010
  • 32 Answers
SOURCE: where is the waste toner bottle for the Gestetner dsc 535
It is located on the lefthand side of the machine under the yellow pcu unit. You will have to remove a cover next to paper tray 1
Posted on Apr 26, 2010
  • 903 Answers
SOURCE: Where is the transfer belt assembly located and
Hi, as you're looking at the front of the 4532, the transfer belt assembly is on the right side. Open the duplex door that hangs off the right side, and then open the right side cover on the copier. You will see a wide brown belt that sits on the door -- that unit is the transfer belt assembly. You can remove it by turning the plastic lever on the front side and lifting the unit off of the door.
The waste toner tank is contained within the transfer assembly. If you remove the transfer belt from the rest of the unit (it's only held in by clips and springs) you can pour the waste toner out by turning the unit upside down so the toner spills out past the cleaning blade. (Make sure you have a trash bag or other container for the toner to fall into.)
Posted on Jul 18, 2010
Where is used toner bootle dsm 635
it has not waster toner bottle on the machine, the waster toner is being recycled in the photo-conductor unit (PCU) so if the machine show replace the waster toner bottle just clean the PCU of the machine on the drum upper area
Sep 21, 2015 | Gestetner 3532 4532 Dsm635 Dsm645 Toner 4...
Where is the transfer belt assembly located and the the waste toner in a gestetner 4532?
May 07, 2010 | Gestetner Copier
Can't find the toner waste bottle to empty it for Gestetner 4532. Where is it located?
Good luck
Apr 14, 2010 | Gestetner Office Equipment & Supplies
Where is the waste toner bottle for the Gestetner dsc 535
Mar 16, 2010 | Gestetner Copier
My Gestetner 3235 will no longer work.
Open the duplexer, open right door the brown belt thing is the transfer and waste toner assy, on the front side of this is a 1.5 inch handle that needs to be lifted to the upright position and rock it away from the copier and place it on newspaper, take the 2 springs off lift the brown belt upper portion up releasing the tab on the front side. now you need to "dump" all the waste toner from the lower half. and reassemble, rember to put it back like it was.
-Carl, please let me know if this helps.
Jun 18, 2009 | Gestetner DSc224 Copier
Hi again! i have a multifuctional machine gestetner dsc428. i print 500A3 full black with b/w print option from the driver checked. After i finished the prints my machine shows a message on screen tha...
Are you using third party toner, or OEM? Toner cart has small chip on it that the machine reads and is being told not OEM toner
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 09, 2009 | Gestetner Office Equipment & Supplies
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Printing envelopes from gestetner 3502P
What size are the envelopes?
Envelopes have to be fed through the bypass. #10 envelopes are not recommended to run through the copier. There too small to feed through the fuser rollers and they will jam.
Sep 03, 2008 | Office Equipment & Supplies
Installing transfer unit
open the front and right door , remove the waste toner bottle . remove old and put new.
don't forget to unlock and then lock the waste toner bottle.
Apr 06, 2008 | Office Equipment & Supplies
Gestetner 3502 / 3502P / 4502 / 4502P / P7145 Copier Machines 89856 Type 3502 Black Toner Bottles 4/Pack 3841 Logo
23 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
