Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
Wire is broke off inside liner of welder feed
Wire broke off and am unable to grasp it with plyers. is deeper in than can get to after dismantling trigger and  inner feed, even after unhooking both ends and removing coil liner to work on it. coud not feed another wire through (beside)  it, either.
  • 3 Answers
Replace coil liner
Posted on Jun 24, 2009
Wire is broken off inside wire feed tube and wont pull through tube either
Hi:
You need to replace the gun's liner. To avoid this problem you must decrease the voltage or increase your wire speed.
A new liner will cost you around 20 buck at your nearest Praxair welding store.
If this was useful to you please vote. Thanks
Apr 15, 2011 | Lincoln Electric Handy MIG K21851 Welder
The wire was not coming out and broke off at connector how do i feed wire back through and remove broken wire?
You need to remove the gun's liner and try to pull it out with pliers, if you can't then just replace the liner for a new one.
If this was useful to you please vote. Thanks!
Feb 17, 2011 | Hobart Handler 140 Mig Welder
The welding wire is broke off inside the feeding hose and I can"t get it out....I have a Lincoln 100
If the welding wire is inside the liner and got stuck, you must change the liner, it is an easy fix. Take the gun off the machine and take off nozzle, and tip holder, you will need an allen key for this. Pull out the liner form the bottom of the gun and replace it with a new one. You can buy new liner at any welding shop/store. I will recommend praxair, the carry the prostar line which is very inexpensive, a new liner will cost you around 15 bucks.
If this answer was useful please vote.
Feb 05, 2011 | Lincoln Welding Tools
My mig welder has stopped feeding the wire. It will no longer feed either end. Is there an easy way to be able to get the wire out? I've tried pulling it out with plyers but it didnt help.
if you have enough wire clamp it in a vise and pull the other end of the weld gun. this keeps everything straight and should allow the wire to pull out of the liner. if that does not work you may have to replace the liner. Let me know if this works.
Oct 20, 2010 | Welding Tools
How do i get the wire out of te welding line if it is broke off inside
Remove the gun assembly off of the unit and carefully remove the liner from the feed tube, at this point you can usually take a spare piece of wire and push it thru the liner and push out the broken wire, if not then pickup a replacement liner from your dealer and install it reverse of the way you took it apart, and you should be back in bussiness. Hope This Helps Don
Dec 06, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Wire broken off inside of liner in mig gun hose
about the only thing to do is take the gun of the unit ,place it straight in line on the floor or bench and try to hand feed the wire back the other way.good luck,this will be a lucky thing if it works.i dont understand how the wire broke off in the first place.
Mar 18, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
Feb 08, 2009 | Miller Welding Tools
Seised wire inside feeding tube
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
Dec 23, 2008 | Hobart Handler 140 Mig Welder
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
375 people viewed this question
Top Clarke Power Products Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
