Question about Health & Beauty
I have a VIP gold 32ho that the bulbs aren't lighting
I bought this use and it worked when I bought it, but when I got it home and reassembled it at home, the bulbs won't light up.
MicrowaveSvc
  • 9098 Answers
SOURCE: night light won`t work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 16, 2008
  • 56 Answers
SOURCE: Whirlpool Gold Conquest refrigerator side light
This may not be the problem now but by the sound of the malfunctioning electronics, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
SOURCE: How do you change the oven's light bulb? How do yu
I couldn't get my cover off either. My solution was to use a pipe strap wrench, very carefully. Rotate the cap counter clockwise to remove it.
Posted on Oct 06, 2010
  • 7353 Answers
SOURCE: 1995 chevy astro van dash
the CGR LTR/DM fuse powers the dome / instrument lights. did you check voltage going into and out of dimmer switch.
Posted on Sep 22, 2011
emissionwiz
  • 78919 Answers
SOURCE: 1996 Chevy Silverado 1500 sometimes my turn
Replace the electronic flasher relay to cure this.
Posted on Apr 24, 2012
Gmc sierra dually 01 - cab clearance lights aren't
Check the fuse but it is possible that a bulb can be out
May 18, 2013 | Cars & Trucks
Rear Turn signal is not working
Aren't your brake lights and turn signal lights on the same bulb, same filament? Recheck the bulb in the rear, as the rapid blinking is an indication of a burnt out bulb. If the bulb is the correct one and is good, check the connector and socket at the housing for a loose or poor connection.
May 26, 2012 | Dodge Durango Cars & Trucks
How to change the light in my gold start microwave
Some are accessible only if the outer cabinet is taken off.
Most manufacturers recommend that only appliance repair shops do this,
because if the cabinet is not reassembled properly, there is a possibility
of dangerous levels of microwave leakage.
home light bulbs
May 02, 2012 | Microwave Ovens
I bought a target pre-lit christmas tree but half of it wont light up even though its all plugged.How do we fix it?
trystarting from the point that bulbs aren't working,take one of the replacement bulbs that usually come with the lights and replace them one at a time.just one replacement bulb to start then the one you took out put it in the next until either it lights up or you reach the last unlit bulb,but hopefully you dont get to the end because if you do then there's more then one bulb thats faulty. I've had that happen alot so dont give up..If the lights are on two separate wiring check for a glass fuse hidden on either ends of plug(wall or tree) I hop that helps.
Dec 03, 2011 | Cars & Trucks
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
Need to change running light next to headlight
hi,sounds easy,you have to remove both mirrors,then remove the valance panel across the bottom of the windshield,this will let you get to the headlight assembly,once you have the headlight bolts undone and moved out of the way,you will see the bolts that hold in the running/park lights,undo those bolts and the unit can be removed,replace the bulb and put back together(test that the lights work before you reassemble it),mr honda certainly doesnt make it easy,but nice bike to ride anyway...hope this helps...cheers
May 01, 2010 | 1986 Honda GL 1200 Aspencade Gold Wing
How to change break light bulb 1997 geo prizem
Step #1 Open Trunk, on inside of the light housing close to the trunk latch area are 2 bolts, Remove them, on mine they were 10mm
Step#2 Inside the trunk are 2 Black clips that hold the carpet down They have flat heads that look like screws but they are actually clips that pop out
Step#3 Peal back the carpet in the trunk and look in the corner of the rear of the light assembly by the fender You will see a nut and the end of a bolt On mine these were gold colored, Remove the nut
Step#4 On the outside of the vehicle again take a screwdriver or such and gently pry the outside edge of the assembly to dislodge the pin holding it in place You cant see it but you will feel when it gives and the whole light assembly will come out toward the rear of the car
Step#5 The brake lights are the bulbs to the inside of the assembly, gently twist the socket counter clockwise and remove it from the housing, Then push down on the bulb and twist it to remove it from the socket, Replace with the new bulb and reassemble everything and You are home free!
Hope this helps, Took me a long time to figure this one out without an owners manual!
Take Care and good luck
Allen
Oct 02, 2008 | 1997 Geo Prizm
Health & Beauty Logo
821 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
