My Robertshaw3110 thermostat needed a battery change then after that I can't get it to work properly. I set the day and time and set the desired temp pushed the hold button but it just dose what it wants and my temp is all over the place
  • 164 Answers
Try taking the batteries out, wait until all the displays are gone and then then put the batteries in and try again.
Posted on May 09, 2014
I couldn't figure out how to amend my last question, so here is one more piece of information. I just put batteries back in and reset the time/date. The Temp Up and Temp Down buttons WORK FINE
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
Jan 31, 2015 | Honeywell RTH230B 5-2 Day Programmable...
How do I turn down my thermostat?.
I think you may be misinterpreting what it's telling you. The up down buttons select the DESIRED temperature, when it goes back to the same number it's showing you the actual temperature, which given time should eventually reach the desired temperature.
May 09, 2014 | Ouellet Heating & Cooling
Thermostat is heating house to desired temp before programmed time
there is a installer setup in this thermostat. do you still have the book?
you will need to gain access to the installer setup/programming and in it you will find a setting called auto recovery turn it off. what this does is after a few days of initally running the system figured out it needed to come on earlier and is starting before the set time to come on... you can turn it off and then will have to adjust depending on insulation value/construction type of home how soon you want it to come on so that it reaches desired temperature when you want...
hope this helps you out,,,
Nov 21, 2011 | Honeywell Programmable Thermostat Heater
I am a florist with a 26 feet src refrigeration box (unit), I cannot control the temp at the desired rate, it keeps fluctuating to a higher (hotter) temp. Need your advise
your going to adjust the thermostat setting if your thermostat is digital type you press it yuor desired temp. ex from 10 to 1 to adjust it to cool if your thermostat is analog to adjust it to cool rotate the knob clockwise to adjust the setting to cool but observe it to get you desired temp.
Mar 02, 2011 | SRC Refrigeration LD126-4 10'6' LongDoor...
Our heater keeps turning on & it won't turn off at the scheduled time. Whats wrong?
Your EMR energy management recovery setting is likely on, this learns when the run times are most efficient for the furnace to reach the desired setpoint at the desired time in the most efficient manner, so a 6AM on time may actually come on at 430 to get to the desired temp setting at the desired time set. look for a EMR or equivalent function.
Jan 12, 2011 | Honeywell Programmable Thermostat Heater
I have 2 goodman heating systems. one for upstairs and one for downstairs. The downstairs works great. With the same temp settings on the upstairs, The blower kicks on and you hear the the flame kick on...
i have seen this just the other day customer called and there thermostat would not maintain temp... changed batteries and after five mins did it again... couple of things need to make sure you have fresh batteries if it takes them in thermostat. also try overriding program by pressing the hold button and set where you desire see if it works then... if it still fails to maintain you need to make sure the unit is not running when it is suppose to be off... if the fan is running and the thermostat is not calling for heat or cool then it is possible the flame sensor on the heater is bad or needs to be cleaned... to be honest based on what you are saying sounds like you got two different items going on....
a sure way to test if your mechanical inclined is take the t-stat apart jump the r terminal to the w terminal go to unit and unplug for 10 seconds and plug back in if everything fires up and stays going you 100% have a thermostat issue...
Dec 31, 2010 | Goodman Heating & Cooling
Lost program instructions freezing
Hi, on a programmable stat, you should be able to raise the temp with the arrow and then push hold temp. feature. This will hold the desired temp and get you heat unless you have a stat problem. Try this and let me know the settings.If this didn't work, make sure the stat is in the auto-heat posistion. Push program and set the time.press again and set the day of week. Repeat this step and set the desired temp for each day of the week and week-end and push run program.You should hear it click on. It takes a min. or so on heat as there is a delay. Make sure the batteries are strong as they run the program. Let me no. Best of Luck, Sincerely, Shastalaker7
Dec 04, 2009 | Honeywell Programmable Thermostat Heater
I turned thermostat down but air won't come on.
do you have thermostst turned to cool, and the other question is do you have a programmerable thermostat if so you need to program your thermostat to the desired temp and the desire time of day and days of the week, and then press run program
Melvin
St Lous
Oct 03, 2009 | Ambiance Designs Heating & Cooling
What does set point time and set point temperature mean
set point time time when the set point temp activates
say i want my house to be 70 degrees while i sleep
i'll set the set point time to 11 when i go to bed, and the set point temp at 70
so to do what youwould like set the set point time for midnight and the thempature fore 55 or lowest seting with will keep the heater off. for the second time setting set point time at 5 am and set point tempature at desired temp
Jan 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
