Question about Freezers
How much it cost to replace a compressor on True Deli-Cases TSID-72-l2
    Sergeant:
    Novelist:
  • 185 Answers
Your looking at a Job that takes about 4 to 5 Hours of labor. Reclaim machine,Vacuum pump, Torch, Silver Solder, Freon, Nitrogen,Liquid line drier, Possible suction line drier if it was a shorted compressor windings. New start components. and then maybe a cap tube depending on what caused the compressor to fail. So with that said you can expect to spend $1500 to $2300.
Posted on May 10, 2014
2 Suggested Answers
masterrrex
  • 45 Answers
SOURCE: How To Replace Relay On True T-72 Reachin
If it's mounted inside a box along with the capacitors there is 1 screw holding it from the back. Often you have to unmount the box from the compressor to access the screw.
Posted on Apr 06, 2012
How to put hardstart kit in compressor GDM-72
depends if it is only a two wire hard start.. then wire it parelel with the run capacitor . place line to line and load to load . load goes to compressor and line to power which is usualy realy the neutral for a 120v compressor since the hot runs to a overload and straight to the compressor
Sep 13, 2013 | True 72 cu. ft. / 2039 liter Commercial...
Where are the Freon nodules for a True GDM-72 cooler?
SEALED SYSTEM REPLACING COMPRESSOR ON COMMERCIAL FREEZER
Aug 08, 2013 | True 72 cu. ft. / 2039 liter Commercial...
What is clixon
It is an overload protection device that cuts the power to the compressor if it draws too much current or overheats. Usually fitted close to the compressor body in a black box with the relay. Test by making sure you have continuity between the pins
May 04, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Apr 04, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True gdm12 evap fan runs all the time evev with the compressor off wiring seems not to have been touched
evap fans will run continuiously on this unit,it is normal. fans stay on to circuilate air evenly inside unit.
Sep 19, 2011 | True 72 cu. ft. / 2039 liter Commercial...
The compressor is running but the fans are not spinning so no cold is coming out.
Coil must be cold enough for the fan delay to turn fans on. If it is and no fans replace delay
Mar 08, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Fans not running, everthing else runs. True model T-72F reach in
In most cases, there is a device located in or on the evap that senses the temp of the evap. This can be a defrost terminator/fan delay. Sometimes they are separate devices and sometimes they are a 2 in 1 device. If the evap does not get cold enough, the fans will not come on. Usually about +20 degree F. It is to prevent circulating warm air after a defrost and to keep from overloading the compressor after a defrost as heat is generated by electric elements. I would look to see if the defrost terminator / fan delay has malfunctioned, then I would check the refrigeration system performance.
Apr 23, 2010 | True 72 cu. ft. / 2039 liter Commercial...
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Freezers Logo
85 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
