Health & Beauty Logo
A
Anonymous Posted on May 09, 2014
Wherecan I find information about an Invacare scooterFixing an Invacare scooter?
The batteries quit...My daughter took them out so I could find the numbers to buy new ones. Son in law replaced the batteries and it isn't charging or running.
  • david robertson
    david robertson Apr 14, 2016
    what type of scooter is it ?
Colin Taylor
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 347 Answers
  • Posted on Apr 14, 2016
Colin Taylor
Expert
Level 2:
Mentor:
Answers
347
Questions
Helped
91279
Points
545
Hopefully you have kept the old set of batteries, I would get them tested plus have the charger tested also.
5 Related Answers
oregoon
  • 175 Answers
  • Posted on Jul 12, 2009
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Anonymous
  • 103 Answers
  • Posted on Jul 29, 2009
SOURCE: Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Oct 01, 2009
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Anonymous
  • 177 Answers
  • Posted on Jun 07, 2010
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Anonymous
  • 2418 Answers
  • Posted on Apr 12, 2011
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
2helpful
I have another problem with my Invacare Pegasus mobility scooter.
You have to get in behind it and see why it pushed back in? Then you can push it back out or re-fix it, or get a new charging socket.
Invacare Corporation - Parts Catalogue
Invacare http://www.invacare.ca > inv_catalog > partsPHII_home
Parts Catalog. Invacare Home ' New Search. Choose Product Category. Product Category, Beds and TSS, Power Wheelchairs & Scooters, Manual Wheelchairs ...
Invacare® Pegasus Series
Invacare http://invacare.ca > doc_files > Pegasus Owners ...
PegasusMETRO, PegasusPRO en Scooter ... 7.2.4 How to disconnect the batteries after charging. ... liquids may require replacement of electrical components.
66 pages
Reset of dash lights RE. Potentiometer -
hi John, the tiller display you got on that scooter , if all of the lights are coming on even when the battery power is low sadly is a faulty component, they are cheap to repair and is now a common problem because they quite old ..
Regards
Rob
1helpful
Where is the circuit breaker for an Invacare Lynx 4 scooter?
Heres a link to the manual
http://www.invacare.com/doc_files/1143205.pdf
Go to page 54 is the service lamp flashing?
Circuit breaker is on page 55
Bunch of things to check on page 53
Get back to me if you still have problems
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
I have an invacare scooter that doesn't work. Can
mcdevito75 here, It could be the battery--ies need re-charge or replacement, online at Invacare.com they can help out, or almost any Medical Supply store in your area.
1helpful
2answers
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
