I have a coleman suncutter model 7448-801 and the fan motor was replaced but instead of it blowing out the top of unit it is drawing in from top and trying to blow out thru the coil is this accurate or is the motor need to be reversed so that it draws in thru the coils and out the top? every other a/c Unit I have seen blows air in my face as I look into it just wondering if this type is opposite or not
  • 47 Answers
I have never seen one that doesn\'t suck air in through the coil and blow out the top. My guess is that the double shafted motor was installed backwards.
Posted on May 10, 2014
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
crouchdash
  • 83 Answers
SOURCE: I need to replace my condenser fan motor.
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
Posted on May 08, 2009
SOURCE: AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
Posted on May 30, 2009
  • 901 Answers
SOURCE: Coleman deluxe blend air ll it starts up
The blowing fan is not rotating at the rated speed. Check the fan capacitor and replace.
Check motor also if the capacitor is not at fault.
Posted on May 27, 2010
  • 146 Answers
SOURCE: My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
Posted on May 28, 2010
Coleman AC Tripping breaker
Fan motor is drawing too much current.
May 16, 2013 | Heating & Cooling
I HAVE A COLEMAN SUNCUTTER A/R MODEL 7430-901. PART OF THE EXTERIOR FRAME IS RUSTING. WHERE CAN I GET REPLACEMENT PARTS?
Johnstone Supply carries Coleman parts, they should be able to help you get what you need.
Oct 25, 2012 | Coleman Heating & Cooling
Coleman Rooftop AC fan stops after 7 or 8 minutes of running. Will turn on again after about 10 minutes on its own.
Remove green (fan run) wire from thermostat, and connect to red wire (power) and see if fan runs, and if it will stay running. That will by-pass thermostat to see if it is problem. If it continues to run, thermostat is problem. If that doesn't cure it, I'd remove cover up top and with power off at circuit breaker, blow compressed air in to motor air holes to make sure it's getting proper air for cooling, as well look for small plastic plug on housing where oil can be added ( few drops) to lubricate motor. Leave cover off and try fan to see if that may help. If at all possible, a clamp on amp meter will confirm if motor or relay is at fault if none of these suggestions help. If amp draw at motor too much, motor may be seizing when warmed up from running. test draw when first started and after running for amount of time that it usually quits, and if noticeable difference, motor is seizing and needs replace. You can also test amp draw at main 120v feed wiring with unit just in fan mode.
Sep 13, 2012 | Coleman Heating & Cooling
May 28, 2010 | Coleman Heating & Cooling
May 27, 2010 | Heating & Cooling
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
I have a suncutter outside air unit and the fan barren has broken and i need a new fan for this unit I have the model # can you tell me where to locate one
Generally speaking the fan motor will have to be removed and taken to an appliance repair supply house. The unit model number will need to be written down and taken with you, but it is best to compare the motors when purchasing.
Jul 27, 2009 | Heating & Cooling
Squirell cage blower motor runs all the time
Relay. You may just have it wires wrong but relays are easy to replace. Rus
Jun 14, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
