Question about Flowtron Home
How to change bulb in bk-190 40 watt - Flowtron Home
What color is the alternator lite wire on 1976 f 100 with inline 6 cyl
It would be easier to pop your head under there and pull out the bulb and see what color the wire is that leads to the bulb.
Aug 06, 2017 | Cars & Trucks
Technical data
lumens is a measure of light intensity
the lower the number the duller the light, the higher the number the brighter the light average shops have a level of limens around 750 as this is the safe light level for eyes
Wattage is current flow ( amps) and was used as a measure to show the intensity of the light
12 watt bulb is dull in 240 volts situation where a 500 watt bulb as in ( quartz halogen bulbs) is something that will blind you
You will notice a change in readings from incandescent bulbs-- the old units that had a filament in them--20 watt, 40 watt,60 watt, 100 watt to fluorescent lighting where the power saver bulbs have a rating of 12 watts is equal to 60 watts of the old bulb ( a rough attempt to show the lumens ratings )
this was an attempt to compare the light intensity so that customers could see how bright the new bulb would be
Now that there are LCD units , the wattage is so low that a comparison cannot be made so the shift is to lumens as a measure of light intensity ---in reality the results are the same
for example a torch with 3 X aaa batteries as a low lumen rating as you can see by the brightness of the light and if you compare that with the lumens rating of driving lights that light up the road for miles
the wattage(amps)for the big lumens rated lights will still be low compared to the head light s in current use
Mar 10, 2016 | Televison & Video
I have 2 hots from 240 raceway and common neutral a 250 watt bulb on 1 hot a 40 watt bulb on other hot cut neutral wire they stay on but 40 watt gets bright the 250 watt goes dim why is that
You change circuit from parallel to series..
In parallel (with neutral connected) each bulb receives full voltage, and then each bulb runs at watt rating.
In series (with neutral cut) the circuit is still complete through the two hots... except the voltage drops after each bulb... which affects the watt output on each bulb.
Mar 17, 2015 | Hardware & Accessories
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
If i was to change headlight globes from 55 watt low/65 watt high to xenon halogen 90 watt low/100 watt high is there any problems
Most OE factory wiring is marginal as far as amperage carrying capability goes. They installed wiring fine for the stock bulbs and switch. A lot of vehicles send power to the lights..head and running...through the light switch on the dash. This causes it's own problems as switches are the weak link in the lighting system.
If you run 100watt bulbs you will need to power the bulbs via a 40 amp relay switched by the light switch so the switch does not carry the amperage load through it's contacts.
Doing so will reduce the voltage drop to the bulbs as a 2 volt drop will cause the bulbs to be only 75% as bright as they would be with the full 13.5 volt running voltage..
You run a fused wire from the battery or power distribution block to the relay that should be mounted within 6 inches of the closest h/l bulb. Then from the relay to the head light bulb/s. The front and rear running lamps can remain as factory as they are low amperage draw and original light switch will work because you now no longer run power to the h/lamps through the switch.
Search the www for schematics for relay switched lamps.
Mar 12, 2014 | Cars & Trucks
The light bulbs on the above stove inverter
The actual wattage of the bulb cannot really change anything, perhaps from 10 watts to 30 watts, may, but NOT 25 watts to 30 watts, There simply isn't enough anything to detect if resistance based... I suspect your dimmer is faulty...
Mar 01, 2010 | Electronics - Others
Need temperature range for a PS550A-BK power supply
  • 100% Burn-in under high Ambient Temperature(50C)
  • MTBF above 100.000 Hrsat 25°C
  • Feb 08, 2010 | LogiSys (PS550ABK) 550-Watt Power Supply
    Did I burn out my chandelier?
    the watts on the bulb doesnt matter but it sounds like your switch is fried
    Jan 04, 2009 | Dryers
    Wiring motion sensor light
    Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
    Nov 06, 2008 | Electronics - Others
    Home Logo
    Top Flowtron Home Experts
    john h
    Tom Chichester
    Are you a Flowtron Home Expert? Answer questions, earn points and help others
