My power socket in front panel for my Honda civic dosnt work How can I fix it?
    Problem Solver:
  • 16 Answers
First check the fuse, in your owners manual look for a section for fuses. Look for a fuse that relates to it. It should say something like power port, it should be a 15-20 amp fuse too.
Posted on May 10, 2014
Car dosnt start
What was the code the mechanic cleared?
Mar 31, 2014 | 2002 Honda Civic
My light power windows switch horn and indicator and four way flasher dosnt work
tell him to fix it
or go to
alldata.com and see what to do.
he do
you do
or other shop do
its your decision.
Jan 04, 2014 | 1998 Honda Civic
Honda civic Cigar lighter not working hondA civic all fuses ok
If the cigarette lighter is the ONLY thing that is not working. Either the wires have been disconnected or the coil is broken. Test the socket with a multimeter. If you have voltage and this checks out, Chances are the lighter itself (the coil) is damaged and should be replaced. If you have no voltage at the socket, the wires are likely corroded or broken somewhere and should be fixed/cleaned/soldered.
Nov 28, 2012 | 2012 Honda Civic
2005 Honda Odyssey left front power outlet doesn't work.Right one works fine.How do I fix
using a test light check the fuses in the fuse panel then check for power and ground at the socket. if one is missing remove the socket and check for power and ground at the electrical connector. if you have both the socket is bad and needs replacing. if you missing one you will have to check that wire to find were the problem is and repair it.
May 14, 2012 | 2005 Honda Odyssey
How do I replace the entire tail light on a 1987 honda civic dx?
if the panel is not damaged or only slightly damaged it should just be a case of removing the damaged tail light and fitting the new one, if all electrics work I would leave the socket
Jun 12, 2010 | 1987 Honda Civic
1996 honda civic dx is overheating after long highway drives. Is leaking coolant from top hose as well. Hoping it is that easy of a fix. Thoughts? Thanks for help!
try making sure cooling fans are working by jumping them to the battery and see if they turn on. also could be the thermostat not opening and building up pressure.
Aug 27, 2009 | 1996 Honda Civic
96 Honda Civic 4 door sedan back passenger window doesn't work with master switch on drivers front door but it does work with the button on the back door. Also front passenger window doesn't work at all...
the wires at the door jamb connector get brittle and crack and break, causing all manner of oddities. and it can certainly be intermittent. like your window rolls down with the door open, but does nothing if the door is closed. wires may need to be repaired or replaced with that molex style plug/connector in the door
Aug 11, 2009 | 1996 Honda Civic
I have a 1995 honds civic and the speedometer has stoped working. Can you tell me where the Vss sensor is and what does it do. Thanks
I would check fuses first, locate speed sensor on the transmission second and see if wires are ok. vss dosnt usuall go out unless its shorted to power
Apr 28, 2009 | 1995 Honda Civic
Front wheel stud on 2005 honda civic
U must remove the hub assembly to replace the stud.
Mar 24, 2009 | 2005 Honda Civic
2003 honda odyssey
I assume you mean the front or rear power accessory sockets. You will need to check two fuses. 1) Fuse no. 8 (7.5A) in the drivers under dash fuse/relay box. 2) Fuse no. 9 (15A) in the passenger's kick panel fuse/relay box. Both these fuses must be good for the accessory sockets to have power.
Jan 25, 2009 | 2001 Honda Odyssey
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
