Question about Contax T3 35mm Point and Shoot Camera
I have a Contax T3. The external dust cover is jammed. Can it be fixed?
It closes properly but does not open fully when turned on.
  • 1,511 Answers
It can be fixed by a camera repair service, not by you.
If you move the device it could lock or and/or fail completely.
Posted on May 09, 2014
The fax/ printer says close adf cover then press stop, the cover is closed down properly and there is no paper jams everything is closed properly ?? what do i do to fix it? thanks!!
the ADF cover is the automatic document feed. make sure the cover above that tray is closed tightly. maybe try opening it and reclosing it. sometime the sensors get jammed up.
Nov 08, 2012 | Office Equipment & Supplies
Carrier jam
To fix the carrier jam, open the printer cover. Remove the cartridges from the carrier. While the cover is open, check inside for any loose transparent strip - the encoder strip. The encoder strip ensures the proper mechanism of the carrier on the assembly. If everything looks fine inside the printer, close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and make sure they are properly inserted and secured in the carrier.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
Cd was still player and I found the player with drawer half open and jammed. I can't get it to sync with correct rotation, enough rotation or fully close or fully open. I can force it and hear the gears...
Rea alligning cds is not hard, but not too easy,the best way is to remove the whole cd changer mechanism and allign it to either one point,while totally disconnected, fully open or fully closed. I mean, the rubber or gear mechanism.
The main point of reference is the nearest part driven by the main motor. For example decide to do it when fully open, arrange everything so as to allow the tray to be fully open.If you get everything right, rotate the motor manually and see if it closes the tray without jamming..If it gets fully in keep rotating the motor and see if it loads the disc.if it does, return the assembkly, the sensors and the cd computer will take over from there ...
Apr 12, 2017 | Sony CDP-C445 5-Disc CD Changer
Error 3 is showing it also says swith off and on
this error mean : paper jam (location) it mean a non specific paper jam occored
follow this step to fix:
1. remove jammed media fro the specified location
2. verify the paper tray is fully closed
3. inspect and/or replace the feed and separation roller
4. ensure there is no obstruction on the path, such as a torn piece of paper
5. open and close the top cover to clear the messaage
6. check sensors andflags for proper operation
i hope this helpful
thanks for using fixya
Jan 28, 2011 | HP LaserJet 3055 All-In-One Printer
Foldable lens cover doesn' t open and closed fully... Thanks.
It's usually merely a grain of sand or dust jamming it. But it's also usually easy to fix. This link outlines repair techniques for a stuck automatic lens cover. Recommend trying the less "risky" ones first before considering the end of the lens.
Dec 27, 2010 | Canon PowerShot A610 Digital Camera
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Close cover 310: cover open, but it isn't
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Nov 23, 2009 | OKI C3400n Laser Printer
Screen says open door clear cartridge jam, press enter. nothing is jamming it.
Open the printer and remove the cartridges and reinsert one at a time carefully. That should take care of it.
This can also happen if any of the covers are not perfectly in place or if there is a small sliver of paper or even dust being sensed by the printer. Open the covers and look for paper parts, slivers or dust and clean out if you find it. Then carefully make sure each cover is closed. Sometimes if you slam them shut the cover can distort enough to not close properly and is being detected as open. You also want to remove the paper trays and check there for jams and make sure the paper feeds correctly.
Oct 23, 2009 | HP PSC 2175 All-In-One InkJet Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Contax T3 35mm Point and Shoot Camera Logo
404 people viewed this question
Top Contax Cameras Experts
Steve
Are you a Contax Camera Expert? Answer questions, earn points and help others
