Question about Toro Garden
How do i adjust the clutch on a 12/32 toro ride on lawn mower model 56175
When i press on the clutch it wont disengage
  • 3 Answers
You need to adjust the belt keeper until it almost touches the belt. The pulley is not good enough for its purpose. The lips are to short for its positioning and purpose. But if u get the keeper right next to it it will eliminate the space needed for the belt to drop down. I fixes more than 100 like this.
Posted on May 10, 2014
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
RonPark
  • 855 Answers
SOURCE: my deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Posted on Nov 06, 2009
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Posted on Aug 23, 2010
How do I adjust the clutch in a toro 20666 mower
there isn't a "clutch" on that mower... tell us your problem and then we might be able to help
Oct 29, 2014 | Garden
How to repair a clutch cable on a toro recycler mower
Did the cable break? Or did it just stop working? In general you have to figure if it came off, break or did the adjustment slip. Readjust if necessary or replace the hole cable or re install it correctly. Simple Question, so many answers. And if all else fails, take it to a lawn mower repair shop.
Aug 21, 2014 | Toro Lawn Mower With Toro Power Tools
Belt came off my model 56175
How old is the mower? Is this the first time the belt came off? Over time belts stretch and end up slipping off, though there should be a spring with a nut adjustment on it, it would work with the handle that puts the mower into cutting. If you have someone pull up on the handle like your going to mow ( make sure mower is off and engine shut off)
as someone is pulling on the handle, trace back and see where the spring is, there may be an adjustment there.
Jul 11, 2014 | Toro Garden
Troubleshoot toro ridinglawn mower starts but refuses to move
If it is hydro-static check to see if the transmission is disengaged it should be located on the back of the mower.
Jul 16, 2013 | Mtd Garden
My toro walk behind self propelled blade disengages how do I adjust it
No adjustment, ensure no obstruction on drive end of cable, replace cable, probably stretched over time.
Jun 17, 2012 | Toro Power Lawn Mower
Toro lawn tractor 72106 blades and cruise disengage while mowing
connect a test light to the clutch connector and see if there is power and ground at the clutch when this happens run the light with some wire so you can watch the light while mowing
Apr 27, 2012 | Garden
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower shuts off when clutch is disengaged.
Check your seat adjustment to make sure you're applying constant pressure to the safety switch under the seat.
Apr 16, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Ride-on Lawnmower wont switch gears smoothly
Hi..my name is Keith..and yes..there is a disc brake..that is your brake/clutch.. and it stops the transaxle..its usually located on the transaxle ..on the right side..i hope this has helped..if now please write back
Mar 31, 2009 | Garden
Garden Logo
142 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
