Question about Dishwashers
Whirlpool du900 The filter has seperated at the seams, came unglued. What kind of adhesive can I use?
    Problem Solver:
  • 17 Answers
Use a high temp water proof epoxy
Posted on Jun 02, 2014
What kind of glue for loose film on 1999 southwind storm 32v cupboard drawers?
The best stuff is expensive, designed for formica application, and usual comes in gallon or larger... but 3m hi strength 90 spray, contact cement or super 77 spray would work. First being best. Recommend 3m 90. http://m.homedepot.com/p/3M-17-6-oz-Hi-Strength-90-Spray-Adhesive-90-24/100151277
Jan 04, 2015 | Cars & Trucks
How do I repair a Dicapac Under water casing for DSLR. The slot for the shutter finger detached. (It was not torn or ripped out)
I suggest using Gorilla glue. Protect areas you don't want to glue and be sure to clamp it tightly. Do not use too much glue since it expands. Once set you should never have a problem again - in that particular part of the casing. I uses such a case for a while, then bought a camera and hard plastic case for my snorkeling photography. Sure beats the soft plastic type.
Nov 21, 2014 | DicaPac WPH10 Waterproof Case for Digital...
My fitflop dress style, the leather strip or covering around the supporting platform is separating or unglued, you can see it from the inside, how can I fix it before it comes apart? I only have the
Go to Walmart and buy some "Shoe Goo"....you will be able to reglue your shoe. I usually put my shoe under the leg of a chair or the table leg, so the pressure holds it into place. Let dry for 24 hours....
Jun 11, 2014 | FITFLOP Clothing Accessories
The passenger window on my f 150 came unglued from track what kinda glue do i use to glue it back
3M Panel bonding adhesive is the proper adhesive. It is about $40. I would recommend thorough cleaning of the window using a razor blade and denatured alcohol. Also, remove the black seat clips and clean this area really well. Leave the window up for 24 hours in a heated garage to let the adhesive cure properly.
best of luck!
Jan 10, 2011 | 2001 Ford F150 Styleside SuperCrew
The window is unglued on the bottom and sides.
The dealer can fix virtually any problem with a late model car. But, if you use epoxy or trim adhesive, you may be able to do the repair yourself.
I once used 'gel' super glue to exactly meter and put glue where it belongs and get an instant bond on rubber to glass or rubber to metal bonding.
Jul 11, 2010 | 2005 Volkswagen New Beetle Convertible
97 tiburon sunroof seal is unglue- do i need to replace or can i do it myself..
Auto parts store, Weather strip adhesive. Make sure clean surface very well. Wipe down with enamel paint thinner (small amount), let dry. Apply adhesive sparingly, very messy if you use to much. Put seal in place and if you can, close your sunroof to hold in place while drying. Let set for a couple of hours and that should do it. P.S. the glue comes in yellow or black.
Jun 04, 2010 | Hyundai Motor 1997 Tiburon
Feul pump leak
yes it is possible that the cold caused the adhesive to seperate. i would definitely replace it now as the new one wouldnt be as quick to seperate i mean the other one has lasted these years
Jan 23, 2009 | 1995 Yamaha XV 535 Virago DX
1998 blazer rear window latch comes unglued from window
You need mirror glue. If this is help, please post as such. If it is a fixya, please post as such.TY
Jan 21, 2009 | 2001 Chevrolet Blazer
Dishwashers Logo
Top Dishwashers Experts
