Question about Sunbeam Best prices 4218 Steam Master Iron with Automatic Shut-Off
How to replace retractable cord os a sunbeam steam iron?
SOURCE: Sunbeam 4214 Clothes Iron with Retractable Cord won't heat.
first, i'll apologize for not posting pictures with this, but i didn't have a camera handy when i "fixed" it. i'll do my best to explain the sitch.
i also have a sunbeam 4124 whose retractor was jammed...the cord would not release more than two feet or so, nor would it retract. i was able to disassemble it, but broke some internal retaining clips meant to hold the retractor housing to the iron. WARNING!! do not attempt this if you do not want to void your warranty. i can only assume that the manufacturer did not want you to disassemble the cord return housing and as such, hid the retaining clips where it would be impossible to disengage them. i got lucky and only broke one set of the retaining clips....if you carry on, you stand a chance of breaking both sets, which will not allow you to reattach the retractor housing to your iron securely. best thing to do is call sunbeam and have them send you a new iron, but if you're bent on fixing it yourself, here's how i did it (you'll need one medium philips head screwdriver):
1) remove the rubber feet from the bottom of the iron. this will expose two screw holes (the third foot under the retractor button has no screw; this is the side where the reaining clips are buried).
2) remove the two screws
3) WARNING! this is where you have a good chance of breaking your iron. pull the base of the iron really hard, rocking it from side to side. there are two sets of retaining clips recessed in the housing of the iron. the button will come with the base of the iron, the entire cord retraction assembly is self-contained. you can carefully use a screwdriver to pry the two halves apart. also, be careful not to pull too hard as the electrical connections between the iron and the retractor assembly has only about 2 inches of slack, though the connections are just wire-nut'd together and could be reassembled in a pinch.
4) after the retractor housing is separated from the iron, remove the housing cap by unscrewing the four screws.
5) carefully separate the two halves of the housing; the spring may be loose inside and could snap out at you.
here's where my iron was broken....the coil spring is contained by a plastic tray that had snapped, probably due to somebody pulling the cord out too hard. a section of the tray had jammed itself into the inside of the housing, immobilizing the winding mechanism. my only recourse was to completely remove the spring and permanently extend the cord all the way (not one of the features i bought the iron for anyway, so what the heck). PLEASE be careful unwinding the spring if you have to do it....wouldn't want anybody poking out an eye inadvertantly.
6) reassemble the retractor housing by screwing the cap back on with the four screws
7) if you're lucky enough to keep one set of retainer clips, snap the base of the iron back on and reattach the two screws located under the feet.
8) rubber pads back in and voila!
hope this helps!
Posted on Nov 03, 2008
landsend
  • 1066 Answers
SOURCE: Sunbeam Steam Master Iron 4048-015 stopped working
any steam iron more than a few years old...usually isn't worth repairing.  Just buy a new one.
Posted on Mar 24, 2009
landsend
  • 1066 Answers
SOURCE: The Sunbeam Steam Master Iron dial will not move off ''clean''
buy a new one at Walmart for $20
Posted on Apr 03, 2009
  • 3230 Answers
SOURCE: sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Posted on Apr 06, 2009
erpaalai
  • 999 Answers
SOURCE: need to clean my sunbeam steam iron and can't find
Fill it with white distilled vinager and sey it in a shallow pan with enough of the same vinager to cover the shoe. Let that sit overnight then try the clean function again.
Eric
Posted on Jun 21, 2009
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Why does the cord to my rowenta iron not fully retract?
pull cord all the way out of the iron, make sure it's flat and not twisted when it gets reeled back in.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 26, 2014 | Rowenta 1500W Steam Iron with Cord Reel...
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
Sunbeam steam iron model #GCSBRS-1 does not give steam. 11/2yr old
I have had the same issue with both of these irons. I bought them both thinking they would be a "better" iron with more steam and have not been happy within the first year of owning them. Thanks for the tips.
Mar 22, 2012 | Sunbeam Irons
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
good luck...
Apr 06, 2009 | Sunbeam Irons
Electric cord don't retract on iron model 4219.
I've contact Sunbeam and they're sending me a new iron.
Aug 18, 2008 | Sunbeam 4214 Iron
Retractable cord
hope this helps!
Jun 12, 2007 | Sunbeam 4214 Iron
Sunbeam Best prices 4218 Steam Master Iron with Automatic Shut-Off Logo
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
