Question about Drills
Dewalt screw gun
Need to replaced the shaft that holds the driver bit I have the part but can't get the old one out
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Posted on May 10, 2014
How do I replace the bit? On Dewalt screw gun
You pull it straight out - just a small clip that holds the bit & the bit holder in place. If it has been in a while you may have to grab pliers to pull it out.
Sep 28, 2014 | Drills
How do I replace the driver bit shaft?
I suggest you should go into that supply store and ask for help, if they are decent, they will surely try to help you, they surely have some experience with that.
May 09, 2014 | Dewalt Versa Clutch Tek Screw Gun DW268
The bit in my Dewalt 6.3 Amp Dry Wall Screw gun will not pull out, how do I get it out to change it and how can I change from a Phillips to a nut driver tip.
The bits are held by a spring snap ring that sometimes takes a lot of force to release.
Spray a little bit of CRC226 into the bit/chuck interface and grab the bit with a set of visegrips and PULL !!!
The CRC226 is available in a blue spray can at Home Depot in the electrical dept and fights rust. A can is about $2.70... make sure to get the 226 as there are other CRC products there.
Jun 27, 2010 | Dewalt 6.3 Amp Dry Wall Screwdriver
What's wrong with my screw gun when the bit keeps falling out when in use?
The bit holder resides in the clutch housing which has a collar with a ball bearing that the notch in the bit holder snaps into. It would seem that the ball bearing has slipped out of the cooler on the clutch housing, therefore nothing is locking it into placed. If you need a diagram, let me know.
Apr 30, 2010 | Dewalt Versa Clutch Tek Screw Gun DW268
Replacing the driver tip on Dewalt Dry Wall Screw Gun
yes,when you look at the front portion of the gun, the tip nozzle thing is actually two separate external parts. The foremost aluminum nozzle and the twisty black plastic thing behind it will pull straight off the piece that is reverse threaded onto the gear box.
Apr 08, 2010 | Dewalt 6.3 Amp Dry Wall Screwdriver
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
Was given a drywall screw gun to use, but I need to change the bit to fit smaller star drywall screws. How do I remove and replace this screw bit?
I use a DeWalt and the bit should just pull off like you would a cordless drill/driver. You might need a little persuasion (vice grips or pliers) because of the constant torque placed on it.
Mar 02, 2010 | Drills
How does the adjustable depth drywall bit work? The bit inside keeps spinning and does not drive screw into sheetrock?
It's not the tip, but the screw gun itself. The screw gun has a clutch on it that allows you to set the screw at different depths. You must adjust the screw gun to the desired depth. The deeper you want the screw to go, the less the clutch will slip.
Jim
Jan 03, 2010 | Dewalt Drywall Screw Setter 50 Pk Part No....
Cord replacement
try this web site .you will need your model .number http://www.toolpartsdirect.com/dewalt/dewalt-18.html
Mar 11, 2009 | Dewalt 6.3 Amp Dry Wall Screwdriver
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
35 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
