Question about Samsung RFG298HDWP French Door Refrigerators
Samsung RFG298HDWP showing error code 1E was told its the freezer sensor. what does this sensor do? does is cost a lot to fix it?
  • Loretta
    Loretta May 10, 2014
    I fixed it thanks to someone that had the same issue on here.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Hold energy saver and lightning buton togethr for reset ... hope it will work
Posted on May 10, 2014
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    I have a samsung Refigerator RF4287HABP that has an error code SE after a power failure. What should I do.
    According to Samsung Customer Support SE stand for Sensor Error... after a power outage... so follow the same procedure as 1e (holding the save energy and lighting button for about 6 to 10 seconds.)
    Jan 02, 2015 | Samsung RF4287HABP 28 cu. ft. 4-door...
    Samsung RFG298 hdwp showing error code 1 E was told its the freezer sensor what does this do?
    It tells the main control board the current freezer temperature. The board then turns on the compressor and fan if needed to satisfy your selected compartment setting.
    May 09, 2014 | Samsung RFG298HDWP French Door...
    1E error code
    The Flex zone Temp sensor is the most common issue. check your model number suffix to make sure the part is correct:
    http://www.appliancepartspros.com/samsung-temperature-sensor-da47-00095e-ap4136048.html
    Best,
    Joe
    Jan 31, 2014 | Samsung RS2534 Side by Side Refrigerator
    Samsung Refrigerator Error Code 1E or IE
    1E error is bad freezer sensor. You would need to either replace PART NUMBER: DA32-10104N behind the freezer evaporator cover or the main pcb PART NUMBER: DA41-00684A
    Mar 15, 2013 | Samsung RF4287HARS French Door...
    Samsung refrigerator rf4287 power out for 5 days when power came back up display screen flashing 1 (or I ) and letter E
    The IE error code is actually 1E. That stands for freezer sensor error. The sensor is reading open or shorted to the main pcb. You need to check the wire connections, from the sensor to the main pcb. I provided you a sensor temperature chart and wiring schematic on the images below. You will need a multimeter to perform the voltage checks. I hope this helps.
    Image 1
    Image 2
    Image 3
    Nov 02, 2012 | Refrigerators
    I'm not sure what all the wild goose chase answers are all about, but you guys are WAY overthinking this and not solving the problem. I'm a 45 year old stay at home mom, decidely and possibly forever "un-handy". The solution is simple, as I just administered it this morning after a self-imposed power outage: Press the "Energy Saver" + "Lighting" button simultaneously for 3-5 seconds and you should be back in business. When this happened on a previous occasion, we had a repair guy come out, although the fridge was operating perfectly bc we weren't sure if that error message was indicating something important. Well, I felt like a schmuck when the guy showed me how to reset the panel (and we were both a bit irritated that phone tech support didn't do a better job of level 1 troubleshooting). So there it is...if your fridge is working fine but showing 1E, press Energy saver + Ligthing at the same time (you may need a flashlight since the panel will be dark).
    Aug 20, 2012 | Samsung RF4287HARS French Door...
    Error message 1E is displayed at start up samsung model SW75C3S
    1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
    May 19, 2009 | Samsung SW62ASP Top Load Washer
    My brand new Samsung J845 washing machine keeps showing an error message (which is not in the manual of 1E. What could this possibly be and how do I fix it?
    I contacted Samsung Australia and was informed that this was a Water Sensor Level fault. The machine will be fixed under their warranty guidelines. Thank you.
    Apr 17, 2008 | Samsung Washing Machines
    Samsung RFG298HDWP French Door Refrigerators Logo
    190 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
