I have a ky32/A air conditioner, no water is dropping in the water tank. It's only coming out through the "continous drainage" hole ... how can I get it to go to the tank?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Open indoor panel remove pipe wash it and then fix it again
Posted on May 10, 2014
bluenadas
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
SOURCE: Water spillage in Dimplex portable air conditioner
Hi Leanne,Bung stays in and you dont take it out until the red light (4th on right on top of unit) comes on, then you empty it taking bung out and use tube to get the water out. It will probably take some time (days of continuous operation) for the light to come on, depending on your humidity etc. For easy emptying, wheel the unit to a bathroom or outside where if it spills a bit it won't matter.
Ours is working okay although it just stopped blowing cold air and is only blowing room temp air. we have guests tonight and its hot! I came here looking for a solution to my prob and found yours!
chhers, Les.
Posted on Jan 08, 2008
  • 3 Answers
SOURCE: Is there a drainage plug or hose on the air conditioner? It's leaking.
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
Posted on Jan 14, 2009
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Posted on Jun 23, 2009
  • 4736 Answers
SOURCE: Drainage problem-water is coming out
The drain pipe may have come loose or it is clogged. I bet on it being clogged. They are not difficult to unclog, using something like a flexible Zip Tie about 18" - 20" long and small enough to fit into the drain tubing. It will help to **** out the clog.
Hope this helped you solve the problem.
Posted on Apr 25, 2011
Why is water leaking on the floor from my haier air conditioner
Window A/C units will dehumidify the rooms as they operate. The unit has drainage at the rear. It is important when installing the unit to ensure that the unit slopes slightly OUTWARD to allow the water to drain to the rear. Otherwise the drain pan fills and the water pours into the room. If the unit IS tilted outward, then check the drainage holes for obstructions.
Aug 01, 2014 | Haier HWR08XC7 Air Conditioner
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Where is the drain pan drain hole on the bottom of the Fridgidaire FAC 127S1A air conditioner?
Good Morning Friend,
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire FAC127S1A Air Conditioner
Hi, I have a Convair TRB portable air conditioner and I dont have an instruction manual. I'm wondering about the drainage outlets on the rear of the unit. The top one (half way down) has a black tube...
No the bottom hole should not be plugged. the bottom hole is the drain for the condensation. If you plug that hole the water will fill up and damage the unit.
Jan 31, 2010 | Heating & Cooling
Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Aug 23, 2009 | Frigidaire FAP094P1Z Portable Air...
Figidaire 25 pint dehumidifier
Check the point on the tank (Bucket) where the hose connects to. Make sure there is no obstruction at the outlet of the bucket to the hose connection. Next make sure the hose has no kinks or no loops that may trap air to the drain. If necessary for a long run to the place of drainage raise the dehumidifier to a higher level for better drainage.
Jun 20, 2008 | Frigidaire FDL45P1 Dehumidifier
Leaking water
I had exactly the same issue after using it for a couple of months.
I fixed it by removing the left panel (the one with the grid) (6 screws and pull the panel down).
There is a small white tray in the mid section toward the back of the unit. the top drainage hole is right there and in my case was completly blocked with wet lint.
!!! the fins of the radiator are extremely sharp...
Jan 13, 2008 | DeLonghi PAC C100 Air Conditioner
External water tank
Dear ziba1--posted the same problem two days ago and it doesn't appear to be on the site yet. Anyway, picked away at this again today (literally took the machine apart) and found the problem to be a clog in the drainage system. This explains why your external tank will not fill and why there is a leak--the drip tray under the compressor is not draining due to the clog in the drainage system. I fixed this simply by taking a narrow device and gently scraping out the drain hole of the drip tray (which is located just below the compressor...the compressor is located on the same side as your air filter). After successfully cleaning out this drain, I proceeded to flush the water out thoroughly with water. Give it a try--worked for me. I had all but given up and had already set up an appointment to have it serviced. Cheers
Jul 25, 2007 | Danby DPAC8399 Air Conditioner
Air conditioner is leaking but lights not blinking
Jun 15, 2007 | Sharp CV-P09FX Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
