Question about Xerox WorkCentre M118 Black and White Copier
How to reset drum life counter on a xerox m118 copier?
My machine comes up with check consumables, replace the drum cartridge on the display.
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
  • 42 Answers
SOURCE: Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Posted on Jun 30, 2008
SOURCE: reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
Valdrinjashari81@hotmail.com
Posted on Nov 30, 2008
fotobean
  • 103 Answers
SOURCE: Our xerox M118 showing an
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Posted on Dec 11, 2008
  • 17 Answers
SOURCE: Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Posted on Apr 03, 2010
How to reset xerox m118 drum counter
Hi Laurynas Straksas,
What very frequently happens with those machines is this. On the drum cartridge, there is a green cover in front. Behind that cover there is a series of gears, one has a flag like tab sticking out. That tab is the drum reset, what it does is makes one swipe past the drum reset switch when you install it and that resets the drum life by swiping a switch one time. That flag has fallen and did not swipe your switch, you can do one of 2 things. You can have whoever you purchased the drum from replace the cartridge, or you can pop off that green cover and manipulate that flag to an Up and to the up position and replace the cover and install the drum in the machine, once the machine runs it will swipe the switch and reset the drum count, turning off the light and allowing your machine to run. Once you take the green cover off you will easily see what I am talking about, Flag will be down, work it until you get it in the up position. That will do it.
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
The fuser error light is on and my Xerox XC 1040 copier will not work. There is no error codes displayed
The drum light can be reset via the control panel. Especially if your copies were good before the light came on. The drum unit is the cartridge that is located right next to the toner cartridge. Reset the light using the following reset procedure:
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 12, 2010 | Xerox Office Equipment & Supplies
Actualy my copier is xerox work centre 5020. My problem is machine is indicate replace the drum cartridge. How can i solve my problem without buying drum cartridge set. Please helpme if any solution is...
Well, since the drum is a consumable, most of the copies is running life span counter. When the drum reached the life span, the message will pop out. Well, if the print out still ok, just ignore it.
Jun 27, 2010 | Xerox WorkCentre M-24 Color Copier
We have a Xerox Workcentre Pro575; it has an error that says drum life warning; we replaced the drum with another drum that we know works, but the error stays on. What else can this error mean
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Nov 04, 2009 | Xerox Office Equipment & Supplies
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
the release lever.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
Printer will not come to ready
Have you looked at the consumables counters in the machine status area to see if any of the drums, toners, fuser, transfer belt , etc have exceeded their life ? One of the consumable items reaching the end of life will not allow you to copy or print just scan.
Nov 14, 2008 | Xerox WorkCentre M-24 Color Copier
Need help
Hi
you havenot installed drum cartridge properly inside the machine or you have installed the drum cartridge of Xerox 5816/5821.
Hope you will do it.
Sep 18, 2008 | Xerox WorkCentre M118 Black and White...
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Drum Life Warning Message
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum. Yes No Press [1], then press [Enter]. The screen will display: Completed. Press [Stop] to return to the Standby Mode. These directions were found on the Xerox website, and worked for me.
Dec 28, 2006 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Xerox WorkCentre M118 Black and White Copier Logo
56 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
