Question about Cuisinart CSB-77 SmartStick Blender
The mixer attachment will not release
My husband used the small mixer attachment, it worked fine, now it will not release.
  • Jeanne Rothenbuecher
    Jeanne Rothenbuecher May 10, 2014
    tried leaving it in the sun all day. DID NOT WORK. Still locked down tight. Will not release attachement.
  • MARWAT
    MARWAT May 11, 2014
    u may use heater fan(for hairs) and lubricate endings
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Warm it in sunlight and then try
Posted on May 10, 2014
Testimonial: "It was very difficult to understand due to misspellings and poor English. I'm not entirely sure I understand what was written."
How can I Loosen the spring blades on a Bamix mixer attachment
You are lucky. they usually fall off mine.
However you can gently ease them off with small needle nosed pliers.
May 23, 2014 | Bamix Blenders
Attachment stuck
try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
May 10, 2014 | Cuisinart CSB-77 SmartStick Blender
JSM900DAAS Jenn Air Table Top Mixer, Flat Beater part
Try Reliable Parts.ca. Everyone else was out of stock for Jenn Air small appliances, but I was able to oder a part for my blender from them. Looks like they ship to USA
Apr 14, 2013 | Jenn-Air JBL800 Work Top Blender
Ticking sound in kitcheaid mixer
Remove the planetary and see if the noise vanishes, if not then you will need to open up the gearbox. It could be the pin retaining the fuse gear or maybe even the fuse gear itself failing. It seems unlikely though as you were only whipping cream and there is no effort in that.
Sep 03, 2012 | KitchenAid Professional 600 6 Qt. Stand...
How do open a Waring WSB40 Mixer
Blender not working,Power supply is ok.
Jul 26, 2012 | Waring WSB40 Blender
Oil Leak-Stand mixer
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 18, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Will kitchen aid purchased in USA work in australia?
The Australian outlets will zap that blender - you need to purchase a 240V to 120V transformer in order to make it work.
Mar 30, 2009 | KitchenAid KSB560WH 5-Speed Blender
Braun blender 4191 motor part does not work. fuse is alright. cannot open the cover in order to asess the damage. please advise.
My GF broke our Braun handheld mixer type 4191 500W, trying to mix some figs, the mixer doesn't do anything anymore. I like the mixer very much. I poked a while trying to open it and look what is wrong. This is what i found to open it. On the top, where the numbers are to adjust the speed: remove gently that lid. Below that you'll find 2e lid with the numbers on (1-5), this you can get open by pressing inside the 2 holes with 2 little screwdrivers, push these 2 black tips away and the 2e lid can be removed. Unfortunately i broke my mixer up trying. Now it's open i see how it was. Good luck guys
May 01, 2008 | Braun MR 5550 M HC + BC MultiQuick...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Blenders Logo
170 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
